Dashdaq install ?
Egt sensor would go on the header collector iirc
From looking at Dashdaq logs I typically see around 800-1000F cruising dependent on engine load. Idle I usually see about from 600-700F once warmed up. 1-3rd pull EGT's seem to top out around 1100-1200F.
Any issues with Dashdaq not reading correctly? Someone telling my elec guy that the Zietronix stuff wont display correct numbers from factory sensors?
C3 pin 2 for rpm which is the camshaft position sensor (it's a pink color but mine was almost peach because the heat changed it) be carful, if you count the pins it will be fine
C3 pin 21 for tps ( yellow )
