MTV's E55 Build Thread
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
That ain't OCD man - my left exhaust tips were hanging at the same angle and and I imagined it was all I could see from the rear - standing out like dogs *****... Unless of course I'm OCD also...
E55 AMG & C63 AMG
Personally I believe your lights look best brighter and cleaner and clearer rather than dulled down next to the silver paint.
Also got some coding done on Friday. Got the following coded:
(Using an AutoLogic, not a true SDS...)
-10c Mod
ROW setting for lighting
Seat Belt chime delete
Lock Beep Confirmation (USA w/ Buzzer setting)
Few Questions I have. . .
With ROW setting, I love the fact that I can now have my Fogs active with High Beams. However, the DRL's are still active as well. How do I delete DRLs? Do I have to choose another setting??
I also couldn't remove VMAX.. Will solve that with a tune or if I find someone that has a proper SDS.
I will also be going to go back to OEM settings in regards to -10c mod. Fan turns on ALL THE TIME now if car is sitting for more than 30 seconds. Definitely not beneficial as it's drawing power.
I wanted to lower the rear end a little more, and we were able to. But the car went back up when we started it. I'll just adjust the rear link and call it a day. Or once again.... find someone with an SDS.
#32
E55 AMG & C63 AMG
Yessir !
Adjusted suspension today. Car had a slight rake effect to it... so I shortened the rear link. Result... 3/4'' lower in the rear. Nice and even now.
#38
E55 AMG & C63 AMG
#39
E55 AMG & C63 AMG
Oil Temp
Is there any way to check oil temp on this car?
The gauge to the right is operating temp (Coolant).. it doesn't seem like the hidden menu displays anything in regards to oil temp either...
#40
'06 E55, '15 Jeep SRT8, '94 Mustang GT
There is only so much range in the factory alignment setup. At your lowered height, which is less than me, you will never get your alignment back in spec, without aftermarket parts, and will be eating front & rear tires.
#41
#42
I believe OP lives in one of the nice burbs of montreal where road condition are sometimes quite nice i.e long stretches of new pavement.
I'm downtown. There is no hope for me. Their is a reason that quebec is the land of Audi. Rear wheel beast like ours do not do well. Plus the aftermarket solutions are terrible.
#43
E55 AMG & C63 AMG
On another note - Did some work this weekend. Noticed a paint chip between rear bumper and quarter panel.
Pulled off wheel, pulled out bumper, sanded and painted.
#46
E55 AMG & C63 AMG
Who is running 5W30 in their E55?
I specifically asked for 5W40 yesterday at the shop (And I always watch them work)... but noticed on the barrel later on, after all was said and done, that it listed 5W30...
I know that thinner oil won't harm your engine, thicker oil can. From my understanding the hot viscosity of the 30 weight oil will offer less protection compared the the 40 weight.
Should I be concerned? I change my oil every 5k KM's MAX.
