Heat coming front the Transmission Tunnel
Old Apr 19, 2015 | 02:00 PM
ShaneC's Avatar
300TE
I picked up my 04 e55 3 months ago and so far having a blast.
I did a search but didn't find any results.
The problem i am having is my arm rest storage area gets really hot and i noticed the drive side of the transmission tunnel next to the drive seat gets really hot. The storage space in front of the shifter gets pretty hot as well. Feels like there is lots of heat coming through after driving.
passenger side of the tunnel does not have any heat.
Any ideas on what could be causing this heat?
Thanks guys
Old Apr 19, 2015 | 02:09 PM
hayseed's Avatar
04 e55
exhaust heat shield missing on drivers side or some insulation missing -- just a guess
Old Apr 19, 2015 | 03:52 PM
mAMG's Avatar
SL55 2003
I have the same problem and found out it is the aftermaket head unit wires and cables that gets hot.
Old Apr 19, 2015 | 08:39 PM
menace2sobriety's Avatar
2004 E55 AMG
Check the temperature of the rear heater settings
When I have mine turned up hot the sides of the armrest gets hot
Old Apr 20, 2015 | 10:31 AM
kponti's Avatar
E63
Along this line, also check if you are getting hot air when the rear temps are set to cold, your valve may be bad
Old Apr 21, 2015 | 09:40 PM
ShaneC's Avatar
300TE
This was the issue. Thanks. but the rear driver temperature sometimes gets reset back to max hot some times by it self i think. anyway to prevent this?
is there an auto setting that i can reset?
Old Apr 22, 2015 | 12:31 AM
ping65810's Avatar
07 E63, 2010 ML350 Diesel, 84 Harley FLHTC
For some reason every so often my car resets to a 72 degree temp for rear, making the tunnel hot. Its weird, but all I do is every so often check the rear temp on the climate control and make sure to adjust as needed. I like my car cold anyways, so keep it at 68 degree.
Old Apr 23, 2015 | 12:42 AM
0-60inAMG's Avatar
2004 MB E55 AMG
DIY: Installing a new Changeover/Heater Control Valve -
this will be your issue and the new one will correct it
Old Apr 23, 2015 | 02:34 PM
PelicanParts.com's Avatar
SPONSOR
Try asking your question here. Usually a technician can help you answer that.
-Luccia
Old Apr 23, 2015 | 10:12 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Tell your kids to quit playing with the controls.
