Please chime in with thoughts re: full brake service.
Old May 7, 2015 | 10:25 AM
uraberg's Avatar
2006 E55 AMG
I am thinking about getting started on replacing all rotors, pads, and fluid.
I have sourced rotors and pads. (are there actually 2006 e55's that only have two pads per caliper?). I'll get the motive power bleeder, with appropriate adapter.
I have STAR to turn off SBC.
Questions are:
Does STAR have a flush program?
What fluid, and how much for a complete flush?
Do the pad wear sensors normally get replaced? How many are on the car?
Thanks.
Old May 7, 2015 | 03:13 PM
Elhonaz's Avatar
W211 E55 2003
Dont know about the pads for sure.. I thought all 55's have same brakes -> 4 pads on each front caliper. 2 at back.
Yes star has the flush program, fluid is originaly DOT4+, and yes replace the senors, one in each wheel OR 2 in front and 1 in the back.. cant remember for sure
Old May 7, 2015 | 03:15 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
1 sensor in the front...
Old May 7, 2015 | 03:42 PM
Elhonaz's Avatar
W211 E55 2003
This isnt a goddamn corolla... 2 front and 1 back. Back is on left side
Edit; speaking about the 4pads/front caliper type
Old May 7, 2015 | 04:42 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
what was i thinking... duh...
Old May 7, 2015 | 05:20 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
You don't need the Motive power bleeder if you have STAR.
http://www.partsgeek.com/mmparts/bra...s/e55_amg.html
Replace all wear sensors.
Old May 8, 2015 | 09:35 AM
uraberg's Avatar
2006 E55 AMG
Allright, so 3 sensors.
Yachtmaster: The diy I read did use a pressurized reservoir in conjunction with Star. Is it enough to just keep the master cylinder filled? (maybe I need to run through a sim in star)
Old May 8, 2015 | 02:08 PM
PelicanParts.com's Avatar
SPONSOR
These DIY Tech Articles should be of some assistance! Look under the "brakes" section.
-Luccia
