Rear vents blowing very hot air when A/C is on (already replaced heater controlvalve)
Old May 8, 2015 | 01:20 PM
moehler's Avatar
2014 CLS 63 S AMG / 2004 E55 AMG
My 2004 E55 is blowing very hot air from the rear vents when the AC is on. I replaced the heater control valve under the wiper motor and still have the issue.
Any ideas what else it could be?
Old May 8, 2015 | 01:43 PM
Denroll's Avatar
'06 E55
It's a really dumb question, but... is the rear climate control temperature turned up really high?
Old May 8, 2015 | 02:11 PM
moehler's Avatar
Not a dumb question... the climate control was set properly. I've tried every possible combination of climate control settings.
Old May 9, 2015 | 09:49 AM
moehler's Avatar
It appears to only be happening if the car gets very hot after sitting in the sun. Could it maybe be a shot interior temp sensor? Has anyone experienced that?
Also, where is the SAM located that controls the heater valve?
Any help is really appreciated.
Old May 9, 2015 | 03:04 PM
Denroll's Avatar
'06 E55
Is it constantly hot, like as soon as the car warms up, or does it fluctuate?
Old May 9, 2015 | 03:37 PM
moehler's Avatar
It fluctuates. It may be fine for 20 minutes, then it blows hot again. Once the rear vents blow hot, they will keep blowing hot for a while. Sometimes I can get it to recover by screwing the with the temp settings, or restarting the car.
It always (I believe) blows hot when max AC is on... I haven't 100% proved this yet, but I believe it to be true.
Old May 10, 2015 | 12:26 AM
IslandS62's Avatar
05 E55, 05 Cayenne TT, 06 Carrera S X51
i would suspect either a defective replacement part, or a missed or bad connection when it was replaced.
Old May 10, 2015 | 05:07 AM
ShawnVenom's Avatar
2014 CLS 550
Same here with that problem.
If i turn the temp up to HI and then back to LO it's fine for about 10mins, then hot again.
Old May 10, 2015 | 12:28 PM
layzie12g's Avatar
2008 Mercedes Benz E63
I'm working on one at work. I'm thinking it is the blend door motors failing. I have the head unit out right now to monitor them after the car runs for 20 minutes to see what they are doing.
Old May 10, 2015 | 01:03 PM
moehler's Avatar
Awesome, please keep us posted.
Old May 10, 2015 | 01:23 PM
Hulk's Avatar
A Merc
Layzie. How difficult was it getting in the blender door area?
Old May 10, 2015 | 02:14 PM
layzie12g's Avatar
I'm working on a CLS. I removed all the trim around the shifter with the boot and knob, then the head unit, but to actually remove the motors is going to be a *****. Right now I have it apart just to see what is happening. Actually removing the motors is going to be a different story. The dash may need to come out.
Old May 10, 2015 | 02:20 PM
Hulk's Avatar
A Merc
Crap, that's what I was afraid of!
Old May 10, 2015 | 02:47 PM
moehler's Avatar
Ugh, I'm 99% sure the dash would have to come out to replace those motors. I could be wrong, but most cars require dash removal. I wonder if mercedes even sells the motors separately. I'm also worried that the whole hvac unit needs to be replaced. What a mess over such a "simple" problem...
Old May 10, 2015 | 02:55 PM
Hulk's Avatar
A Merc
They sell the blender motor actuator
Old May 10, 2015 | 03:00 PM
moehler's Avatar
That's good news.
Old May 10, 2015 | 03:02 PM
Hulk's Avatar
A Merc
Bad news is the install!
Old May 10, 2015 | 03:13 PM
moehler's Avatar
Seriously! The last dash I pulled was a serious pain, seats steering wheel, etc. I can only imagine that the electrical connectors are a mess in this car... At this point, I hope layzie finds nothing wrong with the motors! .
I know this is a complete stretch, but is there any chance it's the multifunction, or possibly the humidity sensor? My temp sensor seems fine (I used the hidden features to verify its reading correctly). If not, I guess it's down to the SAM or actuator motor...
Old May 10, 2015 | 03:39 PM
Hulk's Avatar
A Merc
IMO it's either Sam or actuator
My drivers side back and front are warm
Pressure is good
Freon is good all is good
So either Sam or actuator
I hope front Sam MUCH easier
Old May 10, 2015 | 10:48 PM
KnoxE55amg's Avatar
2006 E55 AMG
I work for Honda. We have had issues with a resistor in center console that runs power to rear control unit. Resistor fails and rear center console vents blow hot. Don't know if our cars have that or not.
Old May 13, 2015 | 01:35 PM
Panzer55's Avatar
E55 AMG 2006
You can try solder a new SAM chip L9997ND Driver chip. You can find the video in youtube
Old May 13, 2015 | 01:54 PM
Denroll's Avatar
'06 E55
Think about any extra wiring you want to do while the dash is apart, if you have to do that. Phone chargers tapped into keyed 12V, speaker wire/RCA cables for a future head unit swap, etc.
And, if you have to do this, take tons of pictures! Then make a kick-*** DIY thread.
Old May 15, 2015 | 06:01 PM
moehler's Avatar
Were you able to determine if the vent motors were failing?
Old May 16, 2015 | 12:17 PM
layzie12g's Avatar
I have not yet. I had to do a trans in a new S550.
Old May 16, 2015 | 12:26 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
yikes...
