UPD supercharger pulley ((install 560 ohm 1 watt resistor into harness?
I've purchased this pulley images in the annex, and I hope your help in the installation of this piece with small urinary I do not know where I have to install this piece of small and I would like you to determine if you can pictures Where do I put this thing in the exact location
thanks.
You are probably going to run lean at WOT. (You should be fine driving at part throttle), but I STRONGLY recommend you talk to a tuner about this.
Also, you will want to read up about this pulley. (search the board for FSP, or fixed pulley)
I have to drive it for about 10 minutes from the shop back to home very slowly. I don't believe it is anywhere near drivable without a remap.
I used Buckhead Imports (BIP) for a box tune that they emailed to me and it was really straight foward to do.
Good luck and enjoy!
