iDle Issues - Please don't disregard, Help Needed
2003 e55 amg
iDle Issues - Please don't disregard, Help Needed --Fixed--
iDle issues
Hello everyone,
Just so you know i have used the searched button | http://lmgtfy.com/?q=e55+rough+idle+ |
Idles rough when warm, and it hesitates at initial acceleration. It also bucks a little at low speeds with low rpms, this seems to trigger the rough idle
Two different diagnostics said that the throttle body was bad
-Replaced TB
Now the throttle response its better and it doesn't hesitates as often on initial acceleration and its smoother when down shifting down all gears
but the rough idle continues when warm
if i turn Off/On the car it goes back to smooth idle with the Check Engine light On
Check engine Codes:
P0507
P0106
Things that I’ve noticed:
*On the S/C Top Right Corner (Driver side) are two Fittings next to each other; one line plugged in, and the other is caped off.
*On the back of Driver side Air Intake Housing, I have what it looks to be a small Elbow Brass Barb Fitting with a hose attached that leads to nowhere.
I have Plugged that hose with a clamp and screw.
Things replaced:
Throttle body (New)
Intake Y-pipe seal
air filters
spark plugs NGK Iridium IX LFR7AIX (One step colder)
Bosch Premium Spark Plug Wire
Valve Cover Gasket Both sides
BOSCH Voltage Regulator
Johnson CM30 Pump
Gas Tank Cap
Transmission Mount
I have not done the Motor mounts yet.
Verified to the best of my ability:
Vacuum Leak hose Clamps on all hoses
I will post images of anything that can be helpful.
I just want to continue driving
my beast without having her go crazy at stop lights. ![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Hello everyone,
-Replaced TB
Check engine Codes:
P0507
P0106
Things replaced:
Throttle body (New)
Intake Y-pipe seal
air filters
Johnson CM30 Pump
Gas Tank Cap
Transmission Mount
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Remove the supercharger belt (or check to see you can spin the drum separately from the pulley). If your supercharger runs at idle, chances are you'll get bucking, or rough idle, and MAP codes.
That hose from the intake goes to your driver's side valve cover, right under the filter housing.
The spinning drum in your video is your supercharger, if it didn't spin I would be worried. It appears the hose you have clamped off goes to a surge tank, perhaps the previous owner had a sensor or nozzle installed there.
Like Shardul said, check the fuel pressure, one of your pictures has the fitting shown to check it.
2003 e55 amg
2003 e55 amg
iDle Issues Fixed
iDle Issues seams to have been fixed with the help of a member of Facebook: e55 amg place! w210 w211 page..
The attached picture is not my own but it was exactly what was disconnected on my SC. So it ended up being a Vacuum issue after all.
Thanks to everyone. your inputs where appreciated....
