E55/E63 Brake Upgrade to S63/S65
Former Vendor of MBWorld
Racingbrake is pleased to announce to make this upgrade package available for E55 and E63 owners.
Stock E55/E63:
Front: 360x36
Rear: 330x26
Stock S, CL, CLS 63/65:
Front 390x36
Rear: 360x26
This will be the similar upgrade package we are offering for C63/C63S upgrading to Black Series here:
https://mbworld.org/forums/c63-amg-w...kes-c63-2.html
Advantage/benefit of this upgrade kit:
Cost less than a dealer's brake job even if you are just looking for replacing your old brakes.
Stock E55/E63:
Front: 360x36
Rear: 330x26
Front 390x36
Rear: 360x26
- More thermal capacity - better equipped for track racing
- Looks nicer behind large wheels
- Can re-use front OE calipers (save money)
- Retain stock offset
- Rotors are interchangeable with "S" stock
- New rear OE calipers (supplied by MB dealers)
- Stainless steel brake lines
- Performance street pads included
- RB light weight two piece rotors; perform better and last longer than stock "S"
This kit can be used for E63 both replacement (2010+) and upgrade (03-09):
Costs less than 1/2 of a dealer brake job, or if you are looking to upgrade your 03-09 to BBK like 10+.
Everything stays the same as OE set up, but our brake package will perform much better and last a lot longer than OE or other aftermarket replacement.
Pictures? I've overheated the brakes on my E55 twice. When I eventually need new rotors I'll probably upgrade to something better then.
03 E55, HB Torana
Link to the kit:
http://www.racingbrake.com/Mercedes-.../mb-irk-22.htm
- 1 Axle set of front two-piece rotors (390x34mm)
- 1 Axle set of rear two-piece rotors (360x26mm)
- 2 Caliper RB light weight aluminum adapters replacing OE's heavy steel adapter for the front
- 2 Rear caliper (brand new from MB dealer for direct mount)
- 1 Car set of RB ET500 street performance brake pads
- 1 Car set of stainless steel braided brake lines
- 2 500ml bottles of Motul RBF 600 brake fluid
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
1- What has been done to prevent this from happening?
2- Are your "racing" brake rotors covered under warranty if you use your car on a "race" track?
Not my car but he was alright. Not trying to f with a sponsor either. Just trying to find out how they have addressed this (seems to be) common problem.
See here
http://bfy.tw/1RWd
See here
http://bfy.tw/1RWd
w211 amg e55
Hey RB, does that mean that I can use this kit for my E55 with standard 18 AMG wheels?
Also do you have a kit where I can replace both front and rear calipers?
Whhen I click on https://www.racingbrake.com/Aluminum...its-s/2435.htm, it does not give me the kit woth calipers
Please refer to our complete brake upgrade/replacement option for E55/E63 in this thread:
https://mbworld.org/forums/w212-amg/...ml#post6538339
Thank you.
Thank you.
See here
http://bfy.tw/1RWd
See here
http://bfy.tw/1RWd
I guess there lack of response means that they have done nothing about it. Good luck to those that actually race there cars with these rotors.
00 C200 & 00 C55 & 06 SLK55
Slip mistakes could happening anytime my friend, even with smartest scientists?!?,
why should we care about >1< mistake and sacrifice --1000000-- success..!!!
--{{{No success without mistakes}}}--
ZAYED,,
ZAYED,,
Anyone with concern of this incident can read the other side of (complete) story here:
http://forums.racingbrake.com/showthread.php?t=1482
Failure was due to customer's retrofit from "re-using his V1 rotor hat to a thicker disc (V2) w/o knowing the V2 rotor offset has changed.
We have hundreds of V2 customers purchased "complete new rotor assembly" w/o any issue.
We can't be held responsible for a customer's own retrofit assembly.
SPONSOR
2007 Mercedes E63 AMG
I have racing brakes front rotors on my 2004 Audi A4 330mm 6 pot upgrade. LOVE THEM.
whenever it comes time to replace my W211 E63 AMG brakes I will definitely look into racing brake. upsizing would be awesome if at that point I had more power.
smallest wheels that are able to be run on the 390/360mm upgrade are 19's? or 20's?
I've had 390mm rotors on my E55 for years and while it has 20" wheels every day, I did try a 19" Kleeman forged 1 piece wheel just for grins and It cleared BARELY. I would probably have put a tiny spacer on the hub first if I planned to run those wheels to anticipate stress deflection in both the suspension and the wheel itself.
If the budget allows I highly recommend the bigger rotors. The calipers are overkill in stock form, upsize the rotors and you get some stopping Gforce like most have never experienced before .
