Realistically, how much should i expect to spend a year on maintenance and repairs
Old Jun 23, 2015 | 03:10 PM
nepats's Avatar
Camry
for an 08 e63 with 60k miles
Old Jun 23, 2015 | 03:11 PM
forcefed4door's Avatar
05 E55, 06 Audi S4
The deciding factor is how many miles per year your gonna drive it
Old Jun 23, 2015 | 03:13 PM
nepats's Avatar
Camry
probably around 10-15k
Old Jun 23, 2015 | 03:17 PM
Max.H's Avatar
E55
That will vary on how well the car was serviced before you had it.
Oil changes, rear tires, cabin filter, air filters and whatever else needs replacement. It could be anything or nothing that year. But, it is inevitable and the day will come when you need some parts replaced $$$
Doesn't matter mileage. actually quite weary of low mileage 10-12 year old car. Those can often become a nightmare waiting to happen. Much rather have high mileage car that has extensive records or replacement.
These cars needs to be driven. They can just sit around, all kinds of issues can happen and it's usually the garage queens that aren't started and driven around.
Old Jun 23, 2015 | 04:30 PM
uraberg's Avatar
2006 E55 AMG
Will you do your own work, or pay someone to do it?
Old Jun 23, 2015 | 04:47 PM
nepats's Avatar
Camry
probably my own unless theyre really hard to work on. Around how much do you think id save by doing it myself?
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
1.5k
Old Jun 23, 2015 | 04:51 PM
nepats's Avatar
Camry
Originally Posted by shardul
1.5k
ok that's not bad, was expecting more by the way some talk about these cars
Old Jun 23, 2015 | 04:55 PM
2000UZJ's Avatar
E55
I feel like I had bought one that was maintained but a few components were on the last leg. I have had 2 OEM plastic pulleys let go ($), airmatic blowout ($$), conductor plate and trans connector ($$) and unfortunately a crank pulley shear off ($$$$$$$ bad installation and ARP bolt). I am probably $4-5K deep in maintenance and repairs over the past 12 months. I still have to do valve covers (leaking both sides), plugs and wires. I am at 94,500 miles and haven't had any catastrophic failures (crank pulley wouldn't qualify as a maintenance failure, just bad luck)
I am about $5K in mods right now ($2K+) of those have been pissed away by the pulley issue.
All in all, once everything was fixed and replaced. It's been several months of track usage (road course) and DD'ing. I am a happy owner. It's not a cheap car, it's not low maintenance. E63 shouldn't be that much different with the exception of a SC pulley, intercooler and extra belt.
Old Jun 23, 2015 | 05:22 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
$3.5-5K per year, tires account for about half the expense (Pilot SS)
An 08 with 60k miles is no garage queen, get a PPI and MB service history there are issues with valve train and head bolts on the 63.
Old Jun 23, 2015 | 05:58 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
I would say 1.5-2k a year. Some it will be more some less but if you plan for that you should be ok. Do everything you can yourself and ask how on this board. It will make jobs that cost thousands down to the 6-7 hundred range.
Old Jun 23, 2015 | 06:39 PM
nepats's Avatar
Camry
Alright, thanks for the replies. Should I get a warranty from the dealership or try to go third party? Anyone buy a warranty from a 3rd party? Any recommendations?
Old Jun 23, 2015 | 07:42 PM
infantry's Avatar
07 E63. 07 STi limited #606/800
I would say aim for $2k and be happy it's less!
Old Jun 24, 2015 | 10:50 PM
0-60inAMG's Avatar
2004 MB E55 AMG
As usual, shardul is correct, $1.5k is on the high side....enjoy the ride!!
