Where to buy trunk tank???
Old 06-28-2015, 09:11 PM
e55amgrocket's Avatar
Dirt Scooters
Single pump up front doesn't flow enough on it own when it's pulling water thru 15 feet of hose from the tank then thru the intercooler and thru the heat exchanger then back another 15ft of hose to the tank. Best setup I found for drag racing (bypassing heat exchanger) was a pump in tank and another pump up front.
Old 06-29-2015, 08:43 AM
jmb614's Avatar
E55 AMG
I've found the same as well, one pump isn't enough. I don't have mine setup to bypass the heat exchanger however, as I have the line from the tank feeding directly to the front pump and on to the intercooler before exiting to the HE, though that is a great idea so as to avoid potential heating of the fluid by the heat exchanger. I've noticed temps go up around 3-5F on my setup, not much but there is a bit of difference.
Old 06-29-2015, 11:49 AM
Denroll's Avatar
'06 E55
Originally Posted by cij911
Why not just use the pump up front (there is no need to install another pump in the tank)....Just get the tank in the trunk and add the lines IMHO...
I made a video showing the flow with just the IC pump (Meziere), just the Rule 2000 pump, and both pumps running together. Quite a bit more flow with both pumps running:
And if you're doing this install, get more than 30 feet of hose just to be safe.
Old 06-29-2015, 04:58 PM
BC928's Avatar
E55 and several 928s
I want one the shape of the spare tire well. Anyone have a good line on those?
Then you can do have circle for each fluid - ic fluid and the other can be water/meth.
Quick Reply: Where to buy trunk tank???
