Be carefulwith Mobil 1 oil filters
Old Jul 18, 2015 | 06:05 PM
MRAMG1's Avatar
S600, GL450, GLC 43
I had a little birdy tell me to look at my Mobil 1 oil filter for my GL450.
Yes I know this is NOT that section, but you nuts are the most active.
Anyway, he was right. The following picture is after only 3000 miles.
As you can see it had already collapsed. I forward this to mobil 1 and have not heard a reply now in over two months.
Long story short, use at your own risk my friends.
Ps: This was there special long life filter to boot, LOL
Old Jul 18, 2015 | 06:37 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Looks like paper, should only use fleece!
Old Jul 18, 2015 | 10:51 PM
stockC43's Avatar
65 Chevelle Wagon w/ C5 frame, 08 ML63, 04 S600, 04 E55,(sold) 00 ML55,(sold) 98 C43-55K Swap
Almost all aftermarket filters are garbage. Use only mb or Mann (oe supplier). Pre 13 gl450's use the exact same filters as the E55's for those who don't know.
Old Jul 18, 2015 | 11:29 PM
E55Greasemonkey's Avatar
This place is a joke.
Do NOT use any filters on ANY Mercedes other than the OEM or MANN equivalent. Period. I've seen countless damaged engines (especially the last few years) from someone trying to save $10 on a filter.
Old Jul 19, 2015 | 08:32 AM
MRAMG1's Avatar
S600, GL450, GLC 43
But that's the real clincher here, the Mobil 1 filter was MORE expensive
In fact, it was the MOST expensive filter I have found for the MB's.
PS: I usually buy the Mann's at rockauto, but I was in a pinch, aka leaving soon for vacation when I tried that garbage.
Old Jul 19, 2015 | 08:54 AM
stockC43's Avatar
You would of been better off not doing the oil change (before the trip) than using that garbage. The good thing is that you hopefully found it before any damage has been done and now you know. I've seen aftermarket filters liitterly crumble apart and the oil pump pushes pieces of the filter through the engine.
Fyi. If your in a pinch. I "think" the Napa golds for mb's are manns. You would need to open the box to check though.
Old Jul 19, 2015 | 07:46 PM
SICAMG's Avatar
2005 e55 AMG
I found this with K@N filters as well. I also in my investigation for as long as I have had the car have been dealing with the oil pump whine with some results. The most dramatic was removing the filter completely after the K@N sucked itself in. I started the car and low and behold....no more whine. So I have determined that that whine on cold start up is the pump cavitating on the suction side. To bad they do not make a racing high flow stainless filter for it because I would love to try one out.
Old Jul 19, 2015 | 07:52 PM
MRAMG1's Avatar
S600, GL450, GLC 43
NO Sir:
Do not use ANY NAPA filters
There Gold for my S600 was almost a 1/2" too short. After I showed them the difference, they said they couldn't get the right one after three attempts.
Note: They still list the bad part number for the V-12's, LOL
Old Jul 19, 2015 | 09:25 PM
stockC43's Avatar
NO Sir:
That may be true for the m275 but I think the 112/113/272/273 filter is a repackaged Mann. It was either the Napa filter or carquest. The filter was stamped Mann hu718/5x or whatever the Mann part number is. I only use mb packaged filters though.
Old Jul 20, 2015 | 08:29 AM
jmb614's Avatar
E55 AMG
So what about filters for cars other than MB? Until this thread I've been using Mobil 1's on our Nissan, I would be surprised if the OEM Nissan filter is better than aftermarket.
Old Jul 20, 2015 | 09:16 AM
stockC43's Avatar
On my girlfriends Corolla I've been using Bosch distance plus filters. From what research I did on spin on's they seem to be the best, but who knows
