2004 E55 : Weird Throttle cutoff issue at WOT
I am having an issue on my e55 that started recently and can not figure it out:
2004 E55 AMG
H/E upgrade with CM johnson pump
550cc injectors
BIP fuel rail
BIP tune
Kleemann Shortie headers with all cats removed
Rear cooling tank
Custom intake system
75 shot nitrous system
belt wrap kit
tcu tune
factory torque converter
I have 16" drag tires on the rear 255 50 16's with stock 18's on the front
Tune is fine, no smoke, no smells, no CELs
What it does is this:
You can be in any gear and go upto 6500 rpm, but as soon as you hit the gas at wot, at 4500-5500 it feels like the car hits a wall : Engine RPM stays up, and then you have to let off the gas, and hit it again, and it will go.. it seems to fight to go beyond 5500 at WOT
Anyone ever experience this?
Bad coil pack? Torque converter? TPS?
Again, with all mods, it has worked perfectly for about a year.. it started doing it recently
You could have failing pumps and are just starving it for fuel at WOT upper RPMs
When mine were dying sometimes it would just not feel as punchy in the upper RPMs and power would fade - I initially thought it was due to belt slip but eventually turned out to be the pumps and fuel pressure
Just a thought
