Surprise I got... and some advise needed
Old Aug 25, 2015 | 10:50 AM
s_ager's Avatar
Volvo S60R
Hey guys... so "funny" thing happend... my neighbor txt me and tells me that I should check my driveway... as he thinks there is big bolt lying there...
Well low and behold.. this is lying on the ground..
https://i.imgur.com/0eXcfpY.jpg
to say this what got into my mind...
Went to check my engine bay... and lookie there... bolt form SC pulley missing
https://i.imgur.com/1wmhMoB.jpg
So for the advise... is it as simple as just screwing it in again and torque it to the right specs... or how f am I???
And yes I did drive on this for like 8 miles, but no hard runs.... I did not know I was missing it.
Hope you guys can advise
Old Aug 25, 2015 | 10:53 AM
jmb614's Avatar
E55 AMG
Bolt that fùckèr back in, torque it down and give it a whirl, IMO.
Old Aug 25, 2015 | 11:05 AM
Efivehundred's Avatar
06 E55(SOLD), 03 E500(SOLD)
Put some loctite on too.
Old Aug 25, 2015 | 11:15 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
you got lucky.
you will need the big washer also since that is missing too.
source both parts from a salvage car since the dealer will only sell them with the SC pulley.
Old Aug 25, 2015 | 11:25 AM
s_ager's Avatar
Volvo S60R
Shardul... first picture shows the bolt and the washer... I can take a better pic.. but I think I have both
Originally Posted by shardul
you got lucky.
Old Aug 25, 2015 | 11:28 AM
shardul's Avatar
then you are set.
Old Aug 25, 2015 | 11:32 AM
s_ager's Avatar
Volvo S60R
Any of yo u know the torque specs?
Old Aug 25, 2015 | 11:44 AM
MTV10's Avatar
E55 AMG & C63 AMG
Damn...... that coulda been bad.
You owe your neighbor a cold beer!
Old Aug 25, 2015 | 01:42 PM
JoeNobody's Avatar
Mercedes
supercharger bolts are only good for one time install?
Old Aug 25, 2015 | 03:37 PM
s_ager's Avatar
Volvo S60R
Shardul... do you know the torque spec....
then you are set.
Old Aug 25, 2015 | 04:13 PM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
Only crank is torque to spec.
Supercharger bolt will work fine until it falls off apparently...
Old Aug 25, 2015 | 04:17 PM
40 lb
Old Aug 25, 2015 | 04:18 PM
shardul's Avatar
You can use the best of multiple times
We tighten it with a impact wrench set to 130psi and use Teflon tape on the threads
Old Aug 25, 2015 | 04:40 PM
s_ager's Avatar
Volvo S60R
I hope you can answer another question. When torque the bolt down, how do you ensure that the Supercharger is not just spinning... how do you keep it from spinning?
s_ager's Avatar
Volvo S60R
thank you
Originally Posted by TheTherapist
40 lb
Old Aug 25, 2015 | 04:41 PM
shardul's Avatar
that is one the benefits about using an impact wrench, you can just hold the magnet in place with your hand.
Old Aug 25, 2015 | 05:45 PM
s_ager's Avatar
Volvo S60R
sadly I do not have a impact wrench here...
Old Aug 25, 2015 | 05:53 PM
shardul's Avatar
hold the magnet with a strap wrench
Old Aug 25, 2015 | 06:59 PM
s_ager's Avatar
Volvo S60R
Hey
That is also what I thought.... but it simply did not work... kept sliding...
So figured out a simple fix... bicycle rubber hose... perfect for it.. will NOT slip at all and then it was a breeze to do.
Old Aug 26, 2015 | 03:11 PM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
40 lb
And red loctite
