Mobil Jet Oil 2
Old 09-02-2015, 09:23 PM
NSWEuroCharged's Avatar
E55, Mazda CX9
Mobil Jet Oil 2
Any Aussie's been able to source the SC oil from in country, if yes, where did you get it from and how much did it cost ?
Thanks,
B
Old 09-04-2015, 05:32 PM
sexyxe's Avatar
04 E55
I got lucky, my work uses it. However I went to the Mobil distributor here and they also sell it... By the box only. If you're lucky try the distributor, I've got grease from them for free before as a box had split open and they couldn't sell it individually. Never know your luck.
Old 09-05-2015, 08:47 PM
TheTherapist's Avatar
2004 W211 E55 AMG >>gone but not forgotten > W123 280E > W124 E280 > W126 380SE
I've purchased os in the past. Coincidentally immediately afterwards when I was changing sc oil a friend came past and was surprised to see I was using Jet Oil II as he had randomly found a dozen cans at the tip and was wondering what to do with them! I grabbed a couple off him but unfortunately didn't bring them with me when moving from interstate! Would have come in handy because as it turns out I currently need some again.
Old 09-08-2015, 06:31 AM
E55, Mazda CX9
I got two tins delivered by www.lubesdirect.com.au $23 each, the guy said he would post to us E55 owners in AUS if they show proof of ownership, you have to sign for it, it's something to do with its aero status. They will also do 20L of Mobil 1.
I went to pull the old oil and there was none coming out (on a slope) , I filled it (on the flat) with as much as 60% of a tin. I'll be changing it again in a week.
Just goes to show first thing you should do is change all the fluids when you buy a used car.
Old 09-08-2015, 07:25 AM
That's good info, I'll give lubesdirect a call tomorrow and order a tin. You probably only needed one tin as you would've discovered as there's enough in there to do 4 changes of oil.
This thread has heaps of good tips and discussion on sc oil refilling.
Old 06-15-2017, 10:37 PM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
It's ester base oil is incompatible with automotive sealing systems. It will destroy them.
Old 06-17-2017, 10:58 AM
larrypmyers's Avatar
16 GLC 19 Volvo XC40 06Corvette Z06
Using it only in the supercharger as specified in the operator's manual.
Old 06-17-2017, 11:42 AM
cmpcpro's Avatar
1956 Oldsmobile 98 Holiday, 2006 AMG S55, 2016 Toyota Camry Hybrid XLE
What's better? The Mobil or Mercedes supercharger fluid?
Old 06-17-2017, 01:35 PM
Does the manual mention anything about brand?
Am guessing it comes from the same company, just in a different container. And if there is any difference in the recipe it is so small as to be of no significance.
If one opts for jet oil you will probably need to visit the local airport fbo to find it.
Old 06-17-2017, 10:16 PM
supreame's Avatar
W211 E55 AMG
Yeah the documents state Mobil Jet Oil II.
Old 06-17-2017, 10:34 PM
cmpcpro's Avatar
What documents? The dealer sold me Mercedes Supercharger Oil.. should I have gotten Mobil?
Old 06-17-2017, 10:50 PM
supreame's Avatar
W211 E55 AMG
The Factory Approved Service Products document. I think you should have Mobil Jet Oil II.
Old 06-17-2017, 11:39 PM
cmpcpro's Avatar
Thanks for the info! The dealer sold me the wrong stuff so I just ordered the Mobil and will return the other stuff.
Old 06-18-2017, 09:46 AM
SICAMG's Avatar
2005 e55 AMG
Wait till you go to change it!!!! What a fantastic stench that comes out of the old supercharger oil.
NOT !!!
Old 06-18-2017, 11:24 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
good idea. the merc stuff is actually rebadged GM oil since the c230 has an eaton (American) supercharger on it that is completely different from the ihi charger found on the 55s. The eaton oil is not compatible with the ihi and you need the mobile jet oil 2.
Old 08-11-2018, 08:36 PM
kkkk's Avatar
W204 C63 Estate
What are the effects of running a 5w30 Mobil 1 esp oil in the M156 ? I got a service and that’s what they put in. Have I damaged anything ?
Old 08-14-2018, 08:30 AM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
The table below was published by Mercedes-Benz in November 2008. It provides the Mercedes-Benz approval number; check your Operator’s Manual for the engine type of your model.
Engine Type MB Approval Number Approved Oil Viscosity Range
M156 229.5* or 229.51 0W-40, 5W-40
M156 engine using 229.5 should use only SAE 0W-40 oil
Factory-approved service products are available at your authorized Mercedes-Benz dealer as well as independent shops and auto supply retail outlets.
Old 08-22-2018, 05:16 PM
Mimi05E55's Avatar
2005 E55 AMG
I changed my sc fluid with the jet oil over the weekend with a syringe. I'll do it again because I know I didnt get all of it out.
Old 08-22-2018, 05:19 PM
carguyshu's Avatar
really the only way to for sure get all oil out is to take the charger off, drain it, then take off the front case and wipe everything down. that's what i did, but i was taking my charger off anyways to put on a different snout for a larger TB and regrease the rear bearings.
Old 08-22-2018, 05:49 PM
Mimi05E55's Avatar
2005 E55 AMG
So true. I got so used to doing it with my SRT6, that it's become easy to do. I just drain and refill several times within a week of driving it.
Old 12-14-2018, 11:07 PM
dave2001auto's Avatar
84 300d 2009 e320 bluetec
Yes if you have a jet engine and money to burn.
top side oil changes — no jacking up the car, removing the under skirt to prevent its foam from the oil. Drain, lowing the car the last 1/2 qt can drain, jacking up the car again, reinstall plug and skirt. Refill.
Old 12-15-2018, 02:21 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Yes. The "Mercedes Supercharger Oil" is for the Eaton blowers on the W203 C Classes. The M113K blower uses the Jet II.
Old 12-15-2018, 02:58 AM
supreame's Avatar
W211 E55 AMG
Old 12-15-2018, 07:42 AM
ouch. Jet oil for real amg.
Old 12-16-2018, 12:06 AM
s.i.f.i.'s Avatar
'03 Brabus E55 K8, '11 C300 4matic
Once more, Mobil jet 2 is the the oil that is used for the m113k supercharger, not the engine oil.
Quick Reply: Mobil Jet Oil 2
