HELP!! E55 AMG sucking in oil through throttle body
Old 06-08-2016, 11:04 PM
V-AMG's Avatar
2016 E63s Wagon - CCB & CF package
Originally Posted by AgSilver
Have the oil level checked with a dipstick. As I recall it should measure between 16cm and 17cm. Hopefully it's just an overfill.
I installed an oil catch-can years ago and the TB remains bone-dry to this day. Prior to the installation, there was always a slight oil residue.
Just FYI and for comparison basis: after draining from both oil pan plugs, replacing filter and adding 9qts (per user manual). Drive for a 15-20 mins, then after car sits overnight, my cluster reads 7.4-7.5qts.
Old 06-09-2016, 02:53 PM
FunkTron's Avatar
2006 CLS55
excuse my ignorance, but when I check oil level via the cluster it just reads "oil level ok"
where are you gents seeing the detailed version?
Old 05-30-2021, 10:58 AM
5150///AMG's Avatar
05' E55
im pretty sure they’re in the menu where they access dyno mode.
Quick Reply: HELP!! E55 AMG sucking in oil through throttle body
