About to change alternator, any tips or DIY? Searched already.
Haven't found any detailed DIY, some out there but not really complete or kinda vague.
Questions:
Is there any fuses I should check that could be blown? Is there a fuse for alternator or something related to battery or charging system?
Is it possible to remove the alternator on an E55 without draining the coolant from the radiator and removing those PITA MB hose clamps for the intercooler lines? How?
If I need to drain coolant, how do I bleed the cooling system? Same way you bleed the intercooler I'm assuming? Just want to be sure.
Alternator arrives in a few days, $165 bucks with core exchange from auto zone. I guess I'll swap my new Bosch VR onto the new remanufactured alternator. Sometimes tells me it won't have a Bosch VR on it.
Anyone have any tips for removal and installation of new alternator?
What I know already:
Disconnect both batteries, remove fan shroud, remove both serpentine belts.
Pictures would help, Thanks in advance.
I removed the double idler pulley, both belts, both intercooler hoses (with pliers), fan shroud, belly pans, drain the coolant in the right bottom corner of the radiator
Some fried electronics and a noisy bearing
New piece going the reverse way
Bleeding the intercooler lines is just connecting a clear hose to the lines and putting it in the expansion tank and connecting 12V (car battery or equivelant) to the pins on the pump and making it run. Just make sure to pinch the hose below the bleed nipple to about 80-90%. Use OEM coolant.
I am thinking about removing the screws for the intercooler hoses and see if that gives me enough play to wiggle out the alternator. If that doesn't go. I'll try to pinch the lines and remove the 2 intercooler hoses for minimum fluid loss.
Thank you papieye!!
It will have to do. Because I already ordered and should be here tomorrow. We shall see. I will report back with results. Thanks
Battery light still on the dash. Anyone know how to get rid of it?
Another strange thing, the AC won't blast all the way it only goes up to low power on the fan. Im thinking the battery light may something to do with it.
I was able to remove the alternator without draining the coolant. So that was a plus.
13.9 volts today and everything else works, car rips.
Mr. Green is right
Do a full charge of both batteries and then reinstall and check voltage prior to starting.
Also to starvingartist when motor is on voltage can go from 13.5-14.2 depending on what functions you are using.
If you are at idle and put on rear defroster, ac fan full blast and seat heaters voltage might even goto 12.9
The voltage on multimeter at initial start up was showing about the same volts on gauge cluster for front and rear battery. 13.8 volts. After 1 day I'm seeing 13.9 volts.
OK both batteries will get another charge. IS that ok to do? Even though I Just did it before driving on it?
Ill charge up the aux battery, maybe the rear too after a load test. I'll report back to it can help some others who may have same issue.
I don't have star. So thats gotta wait till I go back to complete service on my car. Hopefully next week. Thanks for the help!
Battery voltage is 13.9-14 volts today. Its going up as I keep driving it. The car rips, so that's good.
