Anyone trading in a 55 for the E63 biturbo?
The new W212`s are many years ahead of my Cl55/E55 (55s are great cars and lot of sentimental value for many) and it is worth skipping over the 6.2L 63 model if you are looking. Stick with the boosted engines. It is fun test driving one if you are thinking of adding , trading or just want to feel the differences.
The 7 speed trans shifts really fast, adds quickness to the ride and a lot of race feature - options. Plus race start is fun to use on a daily basis form every light.
. Coil spring front end set up with rear air bags really adds to both handling firmness and still maintains ride comfort. Others may be able to chime in on all the new features they like. AMG Biturbo in the 8s could be just around the corner with so many working on the format.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
W213...no comment as I've not been inside one.
The biturbo engine is rock solid and 7 speed wet clutch trans is solid as well. I called MB and spoke to a few master techs about quality and they confirmed drivetrain quality is great. Low end torque is huge and they pull like a train with the 7 speed gearing.
Rear air bags are still prone to failure, just like older cars and I assume the air pump too. Good news is, only have air bags on the rear now. Fuel system is different. MPG is a lot better and even at high speeds. I averaged on a 118 mile trip, at a trip speed avg. of 82mph and still got 22.3 mpg for the trip.
www.ultimatepd.com
Congrats they are really beautiful cars
I often alternate driving between the Cl55 and the E63 Biturbo and there is no turbo lag and stock they will glue you to the seat through all 7 gears. Yes, the older V12 turbos with 5 speeds are fast but also have that smooth quiet power Vs the new 5.5 biturbo has a much more radical feel all the way around. 55`s made 420 to 430 RWHP stock and with a stock biturbo you get 480 to 490 rwhp (new S model near 540 rwhp) and the 7 gears really adds a huge amount of quickness. Per the dyno, they are way underrated from the factory but in realitity , the biturbos have a lot less drive train loss with the new wet clutch trans VS the 722.6. With the electric steering you can just lay this car into the corners with vengeance! I dig the 55`s and keeping mine but just pointing out the biturbos have a lot of power and great new features worth trying out for any AMG enthusiast.
www.ultimatepd.com
my girlfirend even said the E63 makes my E55 and C63 look cheap in comparison
