28inch tall tire on e55
Old Nov 23, 2015 | 05:26 PM
1fste55's Avatar
2005 mercedes e55
Is it possible to get a 28inch tall tire to work on a e55. Would like to try a taller tire to get a better roll out
Old Nov 23, 2015 | 05:59 PM
Max.H's Avatar
E55
28" is a really tall tire. It would effectively lengthen your gear ratio. You would not be passing through the traps at the same high rpm as you would when you keep near stock. But, your car is making big power and you got the spray so it might work!
I would stay away from bias ply tires. the 255 16s look like the proven winner for the fast guys.
Old Nov 23, 2015 | 06:25 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Search Chawkins. Cant remember if he got them working, but he had them on for a few runs I believe.
Old Nov 23, 2015 | 08:31 PM
chawkins2001's Avatar
2006 E55 AMG
I ran them, they fit fine and hooked nice. You will need to run just as tall of a front so it does not go into limp mode.
Old Nov 23, 2015 | 08:49 PM
Mike450's Avatar
2015 gl450
2.62 rear?
It'll put you @140 at the top of 3rd gear with a 6200rpm limit.
MH racemaster 325/17 is 28" tall and a great DR.
Old Nov 24, 2015 | 09:14 AM
blackbenzz's Avatar
haters crazy
He's faster than the fast guys though. I think a slick will help but need a bias ply front runner too
Old Nov 24, 2015 | 10:58 AM
2006 E55 AMG
Definitely need a bias front, I tried without running the fronts and the heavy w211 body wiggled so bad I could not get a full pass in.
FYI, I had the exact same combo with the weistec blower and a 75rwhp wet shot, the 28's never broke loose at the Tree
Old Dec 1, 2015 | 01:06 AM
cmattox's Avatar
18' AMG GTR, 05' E55
What size/brand 18" bias ply tire is 28" tall?
