How often do you go through tires?
I replaced all 4 about 12,000mi ago with bridgestone potenzas and I feel like I'm about due for another set just from the feel and vibration. I don't roast mine off intentionally either.
How about it?
Didn't like them anyway.
I just had to put some new fronts on for my road worthy certificate as they had slightly scrubbed on the inner edge. Which annoyed me as they were still fine. I got personally 7k km from them. The rears are still the same, two 1/4 mile days, plus about 7k km. They have a fair bit of meat to go. I'll swap to Brisgestone Potenza RE003 once they are done.
The W211...not so good. One tire shot at 20K miles; a second marginal; a third not so good; one looks great. I just invested a significant chunk of change into the rear suspension (~$1400) and next week will invest a significant chunk into the front suspension (~ $1800 not including labor) to correct suspension issues. The prices quoted don't include the ~$800 for a new set of tires or the cost of replacing a cracked wheel. Heck, it would be cheaper to replace tires than correct the suspension issues.
FWIW, my old Miata sounds better and better all the time... :-P
I have the UPD camber and toe arms in the rear with most of the camber and toe dialed out when the suspension is on comfort mode. The tires were worn a little more on the inside than the outside, so I had them rotated left to right. I'll probably get another 7-10k miles out of them, which is a whole lot better than the 6k I got out of the last set of rear tires before the camber and toe arm upgrade. This is with a few monster burnouts and quite a lot of the flashing triangle.
How about it?
2k back
