I'm gonna drive this car off a cliff...
Old Feb 28, 2016 | 05:03 PM
WideRide's Avatar
2005 E55 | 1968 Road Runner
Ok, now that I have your attention...
I need some advice from the forum. My car was stock when I bought it (November 2015). Bone stock, low mileage and to me, it was fast even then. I stored the car away because I live in the Northeast. Over the last couple of months, I performed some maintenance and upgrades:
Valve cover gaskets
New colder plugs
Removed SC, changed its oil
EC tune
82mm OEM TB
Kleeman Headers
77mm clutched SC pulley
550cc injectors
Custom intake
Etc., etc.
Put the car all back together and it threw one code: P0112. Low circuit input for the IAT sensor. Fine. Not a big deal right?
So, I changed the sensor and rewired the harness since it was damaged during dis-assembly. Code won't go away. The Torque app I have registers -40 degrees for IAT which means it's not working correctly.
Anyway, I take the car for the inaugural test drive assuming it should be a *******g Ferrari-shredder now with all these mods and accompanying tune. IT'S SLOWER THAN IT WAS WHEN STOCK!!!
It feels on par with my 2012 Maxima....seriously. It starts fine. Idles fine. Changes gears well. Sounds mean. It's just a lame duck. Get into the gas pedal and there's just no violence there at all.
Does anyone have ANY idea what I'm missing here? Is that IAT sensor robbing me a ton of power? Since I replaced the sensor and terminals, I assume there has to be a short in the wiring.
Any help is greatly appreciated.
Old Feb 28, 2016 | 05:17 PM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
It sounds like your blower clutch isn't engaging due to a bad IAT input. Did you log boost with your Torque app?
Old Feb 28, 2016 | 05:21 PM
1970gsx's Avatar
'06 E55
IAT showing -40 will be adding a ton of fuel to compensate for the dense air it thinks the car is getting.
Old Feb 28, 2016 | 07:06 PM
Rocman8's Avatar
E55
-40 is default for open circuit so you will have no sc engagement. unplug from the sensor and while monitoring the -40 value jump the terminals to simulate a short and see if the temp value maxes out over +200 and that will tell you wiring is good. if nothing changes then ohm out the 2 pins and see if there is some resistance value or just an open. start with that.
Old Feb 28, 2016 | 07:17 PM
WideRide's Avatar
Thanks guys. I didn't log boost but that would have been a solid idea
It felt as though there was so SC surge. Makes perfect sense now. I'm gonna have to get this wiring sorted ASAP.
Old Feb 28, 2016 | 07:46 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
I hope it work out for you soon. it should be fast with all those mods
Old Mar 1, 2016 | 10:51 AM
viren.89's Avatar
2004 E55 AMG
I'm not sure where the sensor and all is-but a simple check when the SC doesn't engage is when the wire lossens up and detaches.
There is a small hose near Crank position sensor. Even if you touch it little but with excessive force it becomes loosens and comes out and in that
scenario. It'll feel like a 300hp car with , well like your Maxima.
Not sure if that's the issue but just check the hose. Good luck bro!
Old Mar 1, 2016 | 08:17 PM
LNDMISSL's Avatar
E55 W211, G55 W463, 2010 GT500, 2008 S4 Cab (Wife), LR4
Call Mike. Have him bring over star and at the same time he can check your wiring. I can also lend a hand.
Old Mar 1, 2016 | 08:53 PM
WideRide's Avatar
Thanks Dave. I was at my wits end with this. Jay and I even dug into it a little bit today. I dropped it off at Blackforest tonight. Gonna have them take a look. Hopefully it's an easy fix. I'll let you know.
Old Mar 1, 2016 | 09:29 PM
LNDMISSL's Avatar
If Jason @ Blackforest has it...then it's in good hands. Did you see his cl600 ?
Old Mar 2, 2016 | 12:35 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
ya if AIT is reading -40 your ecu is for sure dumping in fuel.
have your local shop test wiring from sensor to ECU, and repair if necessary.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
