any log tps at the track?
I have a TCU tune and that just lets it rev higher
Ugh, cable throttles FTW.
On tq reduction for shifts it is similar that we reduce power at the beginning of a shift. You may not feel it shifting yet but it is in progress. There is somewhere around .2s of pressure control and fill before a shift begins that you feel. We want to reduce power right before to start the shift at the lowest power and then as the shift completes ramp the power back in. By the time ratio completion is done you are back at full power.
Some brands do a set time of reduction but Mercedes does not. The amount and duration is based off the shift itself. It does get more noticeable as the transmission wears out and shifts take longer. It is a learned amount as well.
There is no gain in quarter times by turning any of this off. And it is hell on the transmission. We have run the same car both ways and it is not measurable in ET or trap speed. Because the car is still accelerating during the shift itself from inertia and it is also still make power. Just reduced power.
Every shift the car makes instead of having 82mm NEAR shifts (we are not talking about at the shift) has 10% less, that will be a 73.8mm tb. When passing the end of the 1/4 mile the car will be passing the trap with a 73.8mm tb, do you think that affects mph trap?
Mine did this with both 74mm and now the 82mm. The more power i've made over the years the more I notice it from head jolt. It's almost like being in a high horsepower stick shift.
I rebuilt my tranny this past December so its just the throttle closing annoyance on mine.
I assume this is one of the things a TCU tune would change.
