DIY: Add Facelift mirrors and assemble/dissassemble facelift mirrors
Old Apr 12, 2016 | 04:01 PM
turbo97se's Avatar
05 E55 AMG, E320 CDI, Turbo E46 M3,IS300 2JZGTE,VQ35 Turbo Maxima, Mercedes 300D
Here is my DIY for updating to Facelift (07-09) mirrors. I have done this before on my E55 but never documented it very well. I just did this on my 05 CDI again. I just don’t like the stock Mickey ear mirrors … sorry. The whole process was about an hour and a half going slow.
1.Remove stock door mirror. There are already DIYs for this so I won’t go into any detail on this.
2.Here is what the door looks like with mirror removed:
3.The facelift mirror has a foam boot on it. Remove the boot and use it as a template to drill the holes
Here is the boot on the end of the mirror
Here is the boot removed and used as a templat
4.Mark the holes with a black marker pen
Here are the marked holes:
5.Drill the holes out. Here is a picture of the holes drilled out
6.Put the foam back on the mounting side of the mirror and mount the mirror. You may need to drill the holes out more if the alignment is a little out.
Here is what the inside of the door looks like after mounting.
7. Add the some bolts and washers. M5 20mm bolts will work. The stock ones from the old mirror will not work.
Here are the bolts mounted:
8.Next need to mount the door mirror switch. I held it upside down it seems. You need to remove the door panel for this and also better access to drill the holes and mount the mirror. I did not DIY the door panel removal process as there are quite a few out there already I believe.
9.I actually forgot to take a picture of the mirror mounted on the car. I will take one when I get back.
I also dismantled the mirrors completely because I was planning on painting them to match the car but I changed my mind and decided to leave them in black so here is a tutorial of how to assemble/disassemble the facelift door mirrors. I may still decide to paint them … we’ll see.
1.Here is the mirror completely disassembled:
2.Insert the turn signal:
3.Add one screw (red arrow) and insert the mirror arm at an angle into the housing. It’s a little tight unless you get the angle just right. The housing then just clicks into place.
4.Add two more screws. as shown:
5.Add mirror mount and install 3 screws:
6.Install the frame and screw in the last 4 screws:
7.Lastly, install the mirror glass. There may be some wires for heat and auto-dimming and then you’re done!
For Auto-fold, coding is in 3 places: CGW, IC and driver's door module. I have those screenshots on my other computer
Old Apr 12, 2016 | 05:51 PM
Eldorado Sean's Avatar
E46 M3, G37s
Pics of mirrors on the car?
Old Apr 12, 2016 | 06:35 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
^ it will looks like a 07-09 lol
Old Apr 12, 2016 | 10:11 PM
E46 M3, G37s
Have I seen a 2007-2009 E55?
Old Apr 12, 2016 | 11:05 PM
BenzHawaii's Avatar
W211 E55 AMG, W211 E320, R170 350, E46 325ci, NSX, EF8 Crx, CF R6
Thanks for posting this DIY. I've been wanting to do this project as well. A couple of questions for you. Is the facelift mirror switch plug and play with the old switch wiring/plugs? Does a MB dealership or shop have to do the coding for "Auto-Fold" or can I do it myself without any star equipment etc? Any help is greatly appreciated!
-Gram
Old Apr 13, 2016 | 12:02 AM
Papieye's Avatar
W211 E55 AMG
Great work man, i have been wanting to this for a while. There is a question mark in this project for me and that is, how do I know which used mirrors to buy if I want to retain my folding, right side dipping, dimming, and heated functions?
I haven't been able to find any good info on that matter on google.
Old Apr 14, 2016 | 05:54 PM
turbo97se's Avatar
To answer some questions:
1. I am out on business and had stated I actually forgot to take pics of it on the car. I thought I had but I did not. It looks like an 07-09 E63. My mirrors are black the car is white.
2. You need a DAS to code the car. My very last statement in the writeup states this.
3. I believe you need to be careful with what mirrors you purchase. I think but not 100% sure that the US mirrors are not auto folding so I did not look within the US. I got mine from Lithuania. Here are the part numbers:
2118101576 LEFT mirror
2118101676 RIGHT mirror
I did not really care about the auto-dim and heated part of the mirrors. Mine came with heated and auto-dimming. But you can add those to the harness fairly easily. I am not sure about the DIP functionality as to whether that is mirror model related.
Old Apr 14, 2016 | 07:58 PM
dchl21's Avatar
I don't know. have you ????????
Old Apr 15, 2016 | 03:16 AM
Max.H's Avatar
E55
Thank You! Ive been wanting to this last facelift update to my E55. Auto folding is a nice feature and so is the auto dimming.
Do they come with flood lights? Not sure what they are called the leds that point down toward your feet.
Old Apr 15, 2016 | 03:28 PM
BenzHawaii's Avatar
I've been looking for facelift mirrors with the same led flood lights you speak of. But can't seem to find any? Maybe the euro version has them?
Old Apr 15, 2016 | 09:11 PM
turbo97se's Avatar
I believe what you are asking about are puddle lights. I have not seen any facelift mirrors with the puddle lights. I have seen aftermarket facelift mirror covers that have the puddle lights but not stock ones. I rarely make use of these lights myself although they would look pretty cool at night.
