Help bleeding engine coolant system
Old Apr 25, 2016 | 09:53 AM
Remnar's Avatar
2004 E55 AMG
Looking to replace the engine coolant on my E55 and I can find the write-up in the WIS, however the technical bulletin describe the use of an vacuum system to fill the radiator coolant. As the cost of such a system is not practical, can anyone provide a work around?
Old Apr 25, 2016 | 11:49 AM
Speedriven1's Avatar
Speedriven
There used to be a good write-up on here, but could find it- maybe someone else with better Search Powers can find it? This is what I found: https://mbworld.org/forums/c32-amg-c...ed-system.html
Old Apr 25, 2016 | 11:59 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
it will self bleed over a couple of days, you will have to keep adding coolant during that time
Old Apr 25, 2016 | 12:03 PM
Werkzeug's Avatar
463, 210, 211
1. Remove coolant reservoir cap
2. Remove two forward belly pans
3. Open radiator drain plug (bottom on drivers side of radiator)
4. Close plug and reinstall pans
5. Fill system with 50/50 ratio water to coolant (best mixed in two jugs)
6. Road test vehicle for 5-10 miles with heater on high
7. Recheck coolant level and correct.
Old Apr 25, 2016 | 12:17 PM
Remnar's Avatar
2004 E55 AMG
Self bleeding good
Thanks everyone for the reply. The pictures of the vacuum attachment kind of freaked me out. I guess the recommended system speeds the process, but I am a patient man and will save the $$$ that the dealership charges for the flush.
Just getting around to change fluids, Coolant, Oil, and Transmission. Probably going to use an indy for the brake fluid change.
Cheers
Old Apr 27, 2016 | 09:56 AM
dougz4m's Avatar
2006 E55, 2010 ML350
Sorry I'm new to MB, just got an E55 this weekend! What are the belly pans? Are those the plastic covers?
Old Apr 27, 2016 | 12:10 PM
06cls55amg's Avatar
06cls
https://mbworld.org/forums/w211-amg/...-pump-diy.html
this guy just posted a video on how to bleed coolant
another diy
https://mbworld.org/forums/w211-amg/...ml#post6472973
all the info you need within the 1st 2 pages
Old Apr 27, 2016 | 01:59 PM
Remnar's Avatar
2004 E55 AMG
Another layer of onion revealed.
I was confused about how the system worked. I thought that the HE circuit was completely separate to the radiator circuit. I found the listed bleeding instructions, but didn't understand that they were related.
Sorry for the nube question.
