Driver side Air Strut Knocking when turn
Old Apr 25, 2016 | 11:54 PM
E55*AMG's Avatar
MB 2005 E55
Please give me some opinion why the driver side Air Strut knocks when turning the wheel. Any ideas are welcome.
I checked all air strut and they seemed to raise and lower properly. After shocks raised, the car didn't sack after I had key taken the key out. There were no sight of any leakage around the strut.
The knocking sound came around the front driver side so I jacked up the car, took off the wheel and inspected it while having my friend turning the steering wheel left to right repeatedly, vice versa. When the steering wheel is turned the air strut move to front and back (assume that's normal dynamic function). Check with a Stethoscope the strut knocks loudest at the modulator (see pic attached) during turns.
Greatly appreciated to your inputs.
-Vic
Attached Thumbnails Driver side Air Strut Knocking when turn-img_20160414_100529.jpg
Old Apr 25, 2016 | 11:58 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Is that modulator knocking or is it echoing a suspension noise from elsewhere nearby?
Old Apr 26, 2016 | 12:07 AM
E55*AMG's Avatar
MB 2005 E55
The vibration and the knocking sound come from the modulator. The other place see to be normal.
The previous owner had a shop worked on the suspension before so not sure if they messed up the air valve or something.
Is it normal for the air strut to move front and back during turns?
Old Apr 26, 2016 | 07:19 AM
2000UZJ's Avatar
E55
The strut is not on any of the steering axis. It should not move. You may want to check the top mounts and make sure they are tight. If all else fails, remove the struck (it takes maybe 20 minutes) and check steering noise at that point. Use a jack on the LCA to return the suspension to mimic normal driving height with the suspension so it's not at full droop.
Old Apr 26, 2016 | 08:18 AM
RVAE34's Avatar
S212/M5T/Z31/240Z/3rd gen Tacoma
It is a knocking or a popping noise? I get a popping/clicking noise when I start to move, start to turn or drive over road changes. MB told me it was the strut but I find nothing wrong. Wonder if you are onto something. The other thread I have been posting on seems to imply it's most likely sway bar, end link or ball joint related. My noise sounds like it comes from up top. Almost as if it's coming from the top of the strut mount.
Old Apr 26, 2016 | 08:32 AM
E55*AMG's Avatar
MB 2005 E55
It is like a moving pendulum - the bottom of the strut swing to front and back direction of the vehicle depends on how we steer the power steering. I will remove the strut to isolate the problem and get write back later today.
Old Apr 26, 2016 | 08:33 AM
thtguy's Avatar
2017 GLS 550
you sure you don't have a worn bushing or ball joint, possibly in your thrust Arm? I believe if you are getting movement from the Strut, it is because the thrust arm has too much movement.
Old Apr 26, 2016 | 08:36 AM
E55*AMG's Avatar
MB 2005 E55
It doesn't make any noise driving straight or moving. Only when turning the power steering wheel. Noise from bottom.
Old Apr 26, 2016 | 08:41 AM
E55*AMG's Avatar
MB 2005 E55
Will inspect the bushing later today after taking out the strut. Where is the thrust arm located in this suspension system?
/B]
Old Apr 26, 2016 | 09:26 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
My strut (Arnott) was binding under the boot and making a popping noise when turning slowly and moving - like when parking. I slid the boot down and sprayed the shaft with Wurth grease. It's been quiet for many months now.
Old Apr 26, 2016 | 09:37 AM
RVAE34's Avatar
I will put it up on the lift when I get home and go through everything. I need to get some good penetrating grease/spray.
Old Apr 26, 2016 | 09:57 AM
BagMan's Avatar
i used Wurth HHS spray. Goes on thick and seems to last a long time.
Old Apr 26, 2016 | 09:58 AM
RVAE34's Avatar
Will look into that, thanks! I may wait until I have some. No sense in removing the underbelly pan multiple times.
Old Apr 26, 2016 | 11:04 PM
thtguy's Avatar
2017 GLS 550
The aluminum arms on the front side are the thrust arms.
/B]
Old Apr 28, 2016 | 02:37 PM
JoeNobody's Avatar
Mercedes
check airmatic compressor that's under the driver side fender. the bracket can become bent or rusted, and it'll rattle around under certain conditions.
Old May 4, 2016 | 12:16 PM
06cls55amg's Avatar
06cls
Dont mean to thread jack , but im looking to replace another drivers strut as i believe my shock in the strut is not dampening and causing the car to drive like a boat at higher speeds. i found one a guy is selling on another forum and he is saying his remanufactured Bilstein is clicking while turning as well. bagman seems to have had a similar issue but just trying to see what else could cause this problem before i blow another $200 on his remanufactured airmatic strut vs a used one.
Old May 4, 2016 | 12:21 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
off lately the arnott units are have issues with the top mounting bolts sheering off
Old May 6, 2016 | 02:38 AM
Sandpit's Avatar
08 E63 AMG
I can confirm this.
Put new arnott units all round on my E63 and one of the top mounting bolts sheared off after about 6 months. My shop guy claimed they were aluminium, which I find hard to believe. Got a shop to work up a repalcement system which is still working, but you could say not impressed doesn't really cover the sentiment.
Old May 6, 2016 | 10:07 AM
Rallyboy383's Avatar
2004 E55
Damn! I just bought new units a week ago! Do the reman units have this problem too?
Old May 6, 2016 | 11:56 AM
Dublinoh's Avatar
E63 AMG 2007
Originally Posted by Sandpit
I can confirm this.
I believe they have a life time guarantee, why not get a replacement instead of a cobbled together solution? By all accounts this is a very reputable company.
Old May 9, 2016 | 01:31 PM
Sandpit's Avatar
08 E63 AMG
Fair question. The reason is that living in the Middle East, a) It's a limited warranty, and b) the price of shipping them to/from Arnott is about the same as buying a new unit, plus the car would be off the road for 3 weeks at least. They may well be reputable, but this episode and a few other issues when dealing with them indicate that reputation and quality are two separate concepts.
Old May 9, 2016 | 03:55 PM
thtguy's Avatar
2017 GLS 550
Is this possibly due to over torquing the nuts?
Old May 9, 2016 | 06:07 PM
E55*AMG's Avatar
MB 2005 E55
I just did that yesterday and the knocking sound went away from the air strut modulator. I disconnect the air strut away from the LCA and the Strut is not swing back and forward - turning the wheel didn't hear any knocking sound coming from the modulator. Turning the wheel causes the lca to slightly shifts front and back in a pendulum motion - that cause the modulator to knock.
Please help me to confirm this - do any of your e55 amg after jacked up the front w/ the tires off - turning the power steering wheel makes the lower inner LCA portion to shift front and back?
Many Thanks
Old May 9, 2016 | 06:13 PM
Dublinoh's Avatar
E63 AMG 2007
Extenuating circumstances for sure, mostly wanted to be sure you knew about the warranty.
Old Jun 7, 2020 | 12:13 PM
E55Greasemonkey's Avatar
This place is a joke.
Old thread but I just went through this with my new Arnott struts and completely rebuilt front end. After Arnott sent me a second new strut under warranty, it was still making the knocking sound when turning, only on the right side for whatever reason. Long story short, the strut does twist slightly when turning. The screwdriver is pointing the the 2 parts that move, and the source of the noise. The solution is: Lift the car, remove the wheel, release the air pressure from the strut (you'll need star diagnosis or similar scan tool) Remove the lower band clamp for the dust boot on the strut. Slide dust boot up. Pry the plastic seat up from the metal seat pad. Apply grease to the surface (note the gray plastic dust where it was rubbing) Reassemble and enjoy the silence.
