How do i remove the clutch pulley off the supercharger???
Old May 5, 2016 | 08:15 PM
w4sim's Avatar
S55K AMG
Hello all
I have a bit of damage on the snout of my supercharger, but to repair it i need to remove the clutch pulley itself.
Now i have removed the supercharger pulley, but theres no nut or bolt for the black clutch pulley behind it.
Iv now taken the snout off expecting there to be a nut on the inside of it, and there just a gearing mechanism behind it. There not nuts or bolts on either side, so are these just pressed together? And of so then how do i pull them apart with damage?
Old May 5, 2016 | 08:27 PM
w4sim's Avatar
S55K AMG
This is not my supercharger but this is what i have done so far, removed the snout from the front.
How do i remove the clutch pulley off the supercharger???-supercharger-20snout-2001_zps9hiyyjd9.jpg
Old May 5, 2016 | 08:29 PM
w4sim's Avatar
S55K AMG
And then seen this gear behind it. But no nuts or bolts toi release either one.
How do i remove the clutch pulley off the supercharger???-supercharger-20snout_zpsv7zow4mz.jpg
Old May 5, 2016 | 11:59 PM
ss.dna02's Avatar
05 E55 AMG
You remove the nut on the front of the pulley. Nothing from inside.
Old May 6, 2016 | 04:28 AM
w4sim's Avatar
S55K AMG
That nut on the front only removes the supercharger pulley, not the clutch mechanism behind it.
Old May 6, 2016 | 06:34 AM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
If you're talking about removing the supercharger coupling drum , without the special Mercedes tool which is prob $$$ and you'll prob damage it ,you can heat up the end shaf that supercharger pulley bearing sits on to about 320° and it will slide right off ,pull the two little pins out first ,they say to use a special tool to take it off however installing it they say heat to approx 320 and slide on ,i've done it twice if you have a map torch and a handheld infrared temperature sensor that's what I would do,and have a thick pair of gloves lol
If you need that drum I have a new one as well as a new upper pulley.but I'm across the pond in NY
Old May 6, 2016 | 07:30 PM
w4sim's Avatar
S55K AMG
Thanking you very much sir
Thats exactly what i needed to know. I had a feeling they were pressed together, just not 100% sure how. I took it to an engineering firm yesterday to try and pull it off and they rang back today and said the press will just shear it all off and make a complete wreck of it.
But looks like heat is the way forward.
By the way, how do you remove the pins, or do they just pull out?
Old May 6, 2016 | 08:22 PM
cnterline's Avatar
I twisted/pulled them out with a vice grip ,
Old May 7, 2016 | 09:15 PM
EREBUS's Avatar
clk63, cls55, ml63, (w210) E55
The most recent released magnetic units have been updated without the pin slots. Even the MB tech was surprised.
Old Apr 10, 2017 | 05:47 AM
ChewyLV's Avatar
AMG E55 V8 Supercharger
Question
Hi folks, does anyone knows how to remove snout shaft and replace bearings? Thanks
Old Apr 10, 2017 | 06:26 AM
w4sim's Avatar
S55K AMG
As said above, you need to heat it upto about 320 degrees and it should slide off.
Do not try to pull it off, it will all shatter before that pulley moves.
