hmm - fluid leaking down from the S/C pulley
if the bearings were going would it leak enough to cause a stream down the driveway? seems a bit excessive if you ask me...
changed it when I replaced the bearing like 12k miles ago...
so - who knows if the plug is gone, how the heck would I get something to plug it back up ? it's not on a spare parts bin I'm sure...
If you really lost the drain plug, here is a pic which may be helpful in finding a replacement.
the tech who swapped it replaced only the amount that he removed if I remember correctly...
thanks for the drain plug pic
it smells like burnt ATF, but the Jet-Oil II smells pretty bad too...
it was dripping from behind the intercooler in the lower grill and the technicians noticed the fluid coming from around the pulley and straight down the block to the underbody tray...
haven't seen it yet today but I hope to chat with the garage guys today...
