WEAR ENGINE PROBLEMS M156.983 . And their causes ( aid)
Old 07-14-2016, 03:08 AM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
Yes.
OEM is $10 x 20 bolts = $200.
ARP through weistec is $999.99
Old 07-14-2016, 08:17 AM
Kamal63's Avatar
Mercedes-Benz W211 E 6.3 AMG
Originally Posted by tw2
Yes.
Mercedes recommends weistec? probably quality between them is too high ; )
Old 07-14-2016, 10:55 AM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
Originally Posted by Kamal63
ARP is more expensive than the original? ) ) even than AMG ?
correct, however made of better quality then amg i would assume. I mean ARP is the leader in the head bolt industry...
Kamal63 (07-15-2016)
Old 07-14-2016, 03:59 PM
tw2
tw2's Avatar
I don't know their exact relationship but I can't imagine why they would recommend a competitors product. If money isn't an issue then definitely get the weistec studs. But unless you are applying forced induction they will be overkill.
Old 07-14-2016, 04:32 PM
cmriv's Avatar
I would think weis attempted to make their own version of head studs and either failed miserably or wouldn't be able to sell them at a cheaper rate then arp. You know how klee and weis are, high dollar for no damn reason! Arp would be overkill for sure if money is a issue.
Old 08-29-2016, 11:43 PM
Kamal63's Avatar
Originally Posted by cmriv
is your oil level correct? As in run engine to operating temperature (oil temps at like 170 degrees F) if i'm not mistaken... let vehicle sit for 5 minutes then check oil level.
It's possible lifters are noisy but first oil level should be correct. If it is looks like you'll need new lifter as said previously.
My suggestion, if you need new lifters, get ARP head stud bolts.....
I have slightly got confused that should be changed; bolts of a head or hairpin!
Old 08-29-2016, 11:49 PM
  #32
Kamal63's Avatar
What of elevator operators you would choose? Black series and standard lifters SLS.... I don't think to tune the engine to increase its power, me her resource is important what it wouldn't break! And to prevent wear of the engine and her weak parts!
Quick Reply: WEAR ENGINE PROBLEMS M156.983 . And their causes ( aid)
