Hi everyone and im glad to be back here.
I sold my 04 e55 stage1 about 18 months ago and my wish came true cuz i found one for very good price. The problem is its not drivable and the guy says that he was trying to put it Park and it didnt. So he tried turning it off and starting it again but obviously it didnt start because its in Drive... I word as a truck driver and haul cars. Im picking it up myslef this weekend and i decided to ask maybe one of u guys have an idea what could be the problem?
And #2, will air compessor work from the battery cuz it sits very low..
Thx guys
E55 forever
Thx guys
E55 forever
Charge the battery, don't boost it. The shifter linkage is visible underneath if you can get it in the air. I don't think it will raise up until you start it.
Maybe i could manually drop in neutral and then start it ???
First thing we need to find out is if the shifter position switch is in the transmission or if it is in the actual shifter assembly.
Quote:
I agree, and disconnecting the linkage will tell you that. My guess is shifter assembly, so that might be a better starting point. I think I remember reading about S class doing this, but haven't seen it over here.Originally Posted by Luxury4play
I misread your post, I don't know where the actual switch is. Somebody here does.
Hey guys! Whoever still here. I couldn’t log in for a longest time but im back.. and the car we spoke about 3 years ago))) here it is))) of course i had to have e63 front upgrade and rims were my luck to find for cheap
soooo the car cost me 3,500$
i winched on the trailer, used a lot of wood cuz it was on the floor. When i got home I connected the linkage together, shifter it in park and walla! Drove it home and driving it every day. Crank pulley just went deciding on should i get an oem size or bigger. Thanks everyone!
Welcome back! A crank pulley is great if you can afford it. Lot's of surface area for belt grip Proper installation is critical. Are you up on all your maintenance?
ExploreQuote:
Im thinking about it, my question is, arent u stretching tentioner or the belt by having a larger crank??
yea i have new plugs new mounts fresh oil, trans flushed but still having that little jerk, read that it could be pwm solenoid.
