Airmatic Air Filter Replacement
Old Aug 22, 2016 | 02:24 PM
V-AMG's Avatar
2016 E63s Wagon - CCB & CF package
Hey all,
I couldn't find a DIY or guidance on how to replace the airmatic air filter on our cars so i decided to post one up. Very easy, definitely a DIY job for everyone.
First of all, MB doesn't specify how often to change the filter so at 75K miles I decided it must be due. Its actually a S500 part, not E specific, hence the part #: 220 320 00 69. Under $15 anywhere you look.
Lift the front end enough that you can comfortably lay under it. Remove the front cover that slips into the bumper and on the drivers side, right behind the foglight, is where you will see the airmatic compressor and the said filter. It has a hose clamp on either end and it sits in a rubber sock-like holder. Pinch the clamps and remove the hoses. Pop new one in and voila. Top hose clamp can be tricky to re-install because its a bit tight, but if you dont succeed in re-installing, remove the foglight and you'll have plenty of access. I didnt need to but it is an option. The arrow on the filter should point up. Though, the ends are not the same size so it'd be tough to confuse which end goes where.
Hope this helps!
Old Aug 25, 2016 | 06:30 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
Why does this need to changed to save the air pump in future repairs?
Old Aug 25, 2016 | 08:16 PM
Dublinoh's Avatar
E63 AMG 2007
Filters load up and restrict flow, pump needs to work harder because of restricted flow. Try breathing through a straw and you'll appreciate why a new filter might reduce stress on the pump.
Old Aug 25, 2016 | 09:55 PM
Preet's Avatar
well said
Old May 8, 2017 | 03:59 PM
MACEDON's Avatar
05 E55, 98 CLK320
Ordered a filter and I'm fixin to replace it when it gets here.
Indy mech said my compressor was too weak... I'm almost positive it just has a hard time breathing.
Any idea if you're gonna do a rebuild soon? Make sure you document it pls:n aughty:
Old May 8, 2017 | 04:40 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
You mean like this?
https://mbworld.org/forums/e-class-w...e-rebuild.html
Old May 8, 2017 | 07:18 PM
MACEDON's Avatar
05 E55, 98 CLK320
Originally Posted by bbirdwell
I done seen't that but it's too hard to follow for my lil peanut brain
Old Oct 16, 2019 | 08:52 PM
antesusic21's Avatar
2008 Mercedes c300
Hi! I know this is an old thread but I bought a w211 e500 that is missing the airmatic air filter totally. I know one hose is attached to the compressor, but I need help with the top air filter hose. Where does that hose attach to? Thanks on your help!
