2008 E63 Power Steering Whine
Old Oct 2, 2016 | 05:53 PM
HykakanAMG's Avatar
2013 E63 AMG
Exclamation 2008 E63 Power Steering Whine
Hi guys, have been noticing a problem fairly often. I drive a 2008 E63 Amg.
When I turn my car left or right, parked or unparked, there is a strong whine/vibration that comes.
Assumed it had something to do with the power steering. I took the car in to an indy and they changed the O-ring but the problem still persists. They should've probably checked if the fluid is low.
So I'm assuming I either have low power steering fluid or my pump bad. Any suggestions? Also what power steering fluid should i be using for my car? Pentosin CHF11S Hydraulic System Fluid (1 Liter) - Pentosin 1405116 ?
Also, do any of you know where the power steering liquid resovoir is? I can't seem to find it.
Any advice would be greatly appreciated.
UPDATE: I found the resovoir and checked the fluid level. It's at max. So it's not a fluid problem.
Old Oct 2, 2016 | 09:21 PM
fila0220's Avatar
W211 E63
How many miles on the 63?
Old Oct 3, 2016 | 07:31 AM
HykakanAMG's Avatar
2013 E63 AMG
Around 77k
Old Oct 3, 2016 | 11:11 AM
Skizz's Avatar
'20 GLE450; '06 CL65
FWIW - My AMG tech says, from his experience, it's a typical problem on the E and C's. He said that they usually (not always), need replacement by 100k, and he's done a number of them. Mine was whining just a little at about 53K mi and he went ahead and replaced it under ELW.
Old Oct 3, 2016 | 12:07 PM
HykakanAMG's Avatar
2013 E63 AMG
Ps pump? Cost to replace?
Old Oct 3, 2016 | 12:11 PM
Skizz's Avatar
Apologies. Yes, pump and it was done under ELW (MB warranty), so the cost for replacement wasn't shown on the invoice.
Old Oct 3, 2016 | 12:16 PM
HykakanAMG's Avatar
2013 E63 AMG
I'm on phone so can't see your location. Are you from socal? Do you have good indy?
Old Oct 3, 2016 | 12:31 PM
Skizz's Avatar
No, sorry, only wish I was in socal. Dallas.
Old Oct 3, 2016 | 06:13 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
mine had the same issue...full fluid as well...
had my buddy at his Indy replace all the fluid with new fluid. all drama gone. buttery smooth and quiet now. step one, if this didn't work I would have proceeded to replace the pump.
Old Feb 1, 2019 | 01:28 AM
E63007's Avatar
07' E63
PS Fluid Bleed DIY
I too have a 2007 E63 and I replaced my pump when I had the heads off ( much easier with Head off! ). Months later when I finally had her all back together, I couldn’t help but notice a loud whining sound whenever I would turn the wheel. Mind you, I refilled the Fluid after having removed the HP Hose to get that rebuilt. I did the prescribed (engine off) lock to lock 30+ times, but the didn’t seem to work!
What did work was getting 4 bottles of fluid, disconnecting the return hose, attaching a clear drain hose to it attached by clamp to a bucket (having a small 6-8 mm socket served as a joiner to both hoses with stay ties wrapped around each side). You’ll have to attach a nipple end fastener to the end which connected to the return hose to keep fluid from spilling out. Then you fill up the reservoir and then turn lock to lock, as you do this the fluid will be expelled from the steering rack while new fluid from reservoir is being sucked into the rack. Be sure to constantly fill up the reservoir while you are doing this being sure to allow the air bubbles from pouring the fluid into the reservoir to dissipate before turning the wheel lock to lock. You don’t want those bubbles being sucked into the rack! While turning the wheel lock to lock notice the color of the fluid. Mine was pretty dark until I I saw it turn lighter. I also noticed that bubbles appeared in the hose towards the end after 3 bottles of fluid! I kept bleeding until I saw no bubbles. After doing this, mine turned out much quieter. You’ll then have to reconnect the return hose ideally using the proper Oedecker Clamps.
