Whine noise sounds like pwr str pump
Old Oct 31, 2016 | 07:11 AM
Rb30e's Avatar
2004 E55
Hi all,
Dead keen on joining the club, went to look at a 2004 AMG E55 today. Car has about 110000km or 65k miles thereabouts. Everything looked good on the car it has the full service history and had been serviced more frequently than 25000km stated interval which seems like ages. One thing that stopped me from putting a deposit on the car there and then; it sounded like the power steering pump was gone on it or so I thought. Same sound as a problematic power steering pump but the sound did not change tone when the steering wheel is turned. I couldn't figure it, wasn't coming from the supercharger which I thought may have been the case or any of the idlers. The mechanics who were checking over it for me seemed to think it was just noisy operation of the drive belt because its heavy duty and has to drive the supercharger. Dunno if this is an accurate diagnosis although I hope it is as then I will definitely put the deposit down tomorrow. Just wanted to research a little more before spending my hard earned.
Any advice would be much appreciated.
Thanks!
Old Oct 31, 2016 | 10:37 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Does it only happen the first few minutes of cold start-up?
https://mbworld.org/forums/w211-amg/...tion-pump.html
Old Oct 31, 2016 | 11:14 AM
somebodytoo's Avatar
e320
Hello there.. Very well could be the Transmission front pump . If you are getting a
"great"deal , it is possible the seller is quite aware..
Old Oct 31, 2016 | 01:00 PM
E55wannabe's Avatar
E55 w211
My A/C compressor is pretty loud, loud enough where I plan on changing it. That could be your culprit too.
Old Oct 31, 2016 | 01:33 PM
e320
So here is the list of possibilities from least to most expensive
Idler belt pulley
P.s. Reservoir causing aeration of the fluid
Supercharger bearing,
Air injection pump ( only for 2 min when cold)
P.s. pump itself.
A/C compressor
So a good technician should have no problem isolating the issue.
Good luck !
Old Oct 31, 2016 | 01:36 PM
SICAMG's Avatar
2005 e55 AMG
I will guess oil pump. Take vid if you can that would help.
Old Oct 31, 2016 | 03:04 PM
Rb30e's Avatar
2004 E55
I'm guessing it's the oil pump after reading the thread supplied.
it was definitely there the whole time and not the air pump.
Will have to ask the mechanic to check if the noise goes away once rpm above 2000 which most people have claimed theirs does.
If it's the trans front pump I'm guessing it will also increase with rpm but be there the whole time. Where bouts does this noise come from exactly? If that's the case what are they worth to replace?
I found this vid on YouTube it sounds exactly like this-
https://m.youtube.com/watch?v=kEn4-dlJWqM&rdm=29xz4o5fg&client=mv-google
thanks all for the advice. Really appreciate it!
Old Nov 1, 2016 | 10:26 AM
e320
wow, that should be pretty easy to find... I would start with removing the belt and running it that way to see if it goes away..
Where are you located.. I actually do Mercedes repair.
www.mobilembzspecialist.net
I usually do not spend time here but it is slow and brushing up on
unusual problems..
Rick
Old Nov 2, 2016 | 02:29 PM
kenneyd's Avatar
poop
If if goes away in 2-5 minutes is completely normal, they all do that.
