Jerry at EC is a "Magic Man": Dyno tune #s
Old Dec 18, 2016 | 07:49 PM
rawdvm's Avatar
'04 E55 AMG
New dyno tune & I am more than pleased to say the least: 624 whp/607 wtq @ 6100 RPM & 18.65 lbs boost on 93 octane pump gas (it actually hit over 19lbs boost on multiple pulls)! This pull was with the trunk tank iced down & the IAT went from 73F at the beginning of the pull to 140F when the heat caused the power to drop. Jerry says that there is more hp & tq in the motor if we can keep the IATs down. SO, water-meth injection is coming & then another dyno tune. BTW, for those wondering how the MAP sensor didn't trigger limp mode at boost over 17 lbs, Jerry is a magic man.
Old Dec 18, 2016 | 08:46 PM
J J's Avatar
J J
Wow, congrats, whats the pulley combo?
Old Dec 18, 2016 | 09:03 PM
rawdvm's Avatar
'04 E55 AMG
Weistec Modular CP: 170mm; Weistec S/C pulley: 62.5mm (Weistec supercharger)
Old Dec 18, 2016 | 10:23 PM
BlackHammer's Avatar
2006 E55
Congrats!
What kind of dyno?
Totally bad azz (the engine, dyno #'s, etc). I am guessing you have one of the highest non-NOS E55's (?).
Meth injection will help huge with IAT's. See JMB14's set up. State of the art...
Keep us posted on progress.
Old Dec 19, 2016 | 08:19 AM
rawdvm's Avatar
'04 E55 AMG
Thanks. The dyno is EC's dual roller DynoJet in Houston (it's like a Mustang Dyno). The motor is one Jerry built: Darton sleeved out to 5.9L, Mahle pistons, Carrillo rods, ported/polished heads with bigger valves. This tune was after breaking in the engine for a few months & changing the CP from 150mm to a 170mm. She's my daily driver & the power is addicting. I will get another dyno tune after I install the water-meth kit.
Old Dec 19, 2016 | 09:43 AM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
That's pretty damn cool
Old Dec 19, 2016 | 10:46 AM
2006 E55
Just saw (more like "internalized") your pulley combo: 170/62. That is AGGRESSIVE! Thanks for answering my questions...
Did you log your pulls? If so, can you post logs?
Also, I would like to see a rolling 60-130 pull on video. Surely you have access to a closed course or airstrip.
TK
Old Dec 19, 2016 | 04:02 PM
Max.H's Avatar
E55
Congrats, I see 700 whp in your future.
Old Dec 19, 2016 | 04:40 PM
RBM113K's Avatar
03 E55
Take her to the track
Old Dec 19, 2016 | 05:16 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
You have a beautiful car Mr. Richard!!!
-Tiff
Old Dec 19, 2016 | 06:45 PM
blackbenzz's Avatar
haters crazy
Congrats! Wonder if Jerry used a similar file to mine. Meth will help you. Ever thought of running the 1/4?
Old Dec 20, 2016 | 10:16 AM
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
Congrats! The ECU is dumping fuel early. I bet you would put more down with the older pulley set up and keeping the IATs in line. Meth is a must if you live in Houston. Im in the process of redoing mine right now.
Old Dec 20, 2016 | 11:45 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Awesome, sounds like a staggering amount of safe, daily drive-able power!
Jerry is quite the wizard. I have always appreciated what he has done for my cars : )
the 17 pound ceiling circumvention must have some interesting details (use a MAP sensor scaled for a larger boost sweep and then compensate in the tune? I would be curious to see how your OBD2 boost compares to actual boost)
Great work !!
I look forward to hearing more about it and to you getting many, many miles (and quarter miles : ) of joy out of it !!
Happy Holidays!
Chris
Old Dec 20, 2016 | 12:12 PM
rawdvm's Avatar
'04 E55 AMG
The boost readings were read directly from the intake by the dyno (we attached a line from the dyno to a port on the intake just in front of the MAP sensor).
Old Dec 20, 2016 | 02:01 PM
2006 E55
Just a guess on my end is that part of the reason Jerry tweaked to allow more boost is you have an upgraded/stronger motor that Euro built?
My sense is this type of "love" (more boost capability) isn't likely readily available for just anyone?
TK
Old Dec 20, 2016 | 02:09 PM
CerBErusM113's Avatar
2015 CLS63 S AMG
God Damn! Very nice :-) Thanks for pushing the bar. I have new goals now!
Old Dec 20, 2016 | 02:23 PM
rockthemullet's Avatar
2005 Mercedes E55 AMG
Originally Posted by BlackHammer
Congrats!
What kind of dyno?
630whp/680wtq, 14psi, stock blower, no spray here...
Old Dec 20, 2016 | 02:35 PM
rawdvm's Avatar
'04 E55 AMG
TK
Down the road, I may convert to E-85 & gain more power
Old Dec 20, 2016 | 02:39 PM
rawdvm's Avatar
'04 E55 AMG
That's very impressive for a stock blower & no spray. I assume the E-85 helps a lot. Who did the conversion for you? I am thinking about doing an E-85 conversion down the road. Have you had any issues?
Old Dec 20, 2016 | 04:52 PM
trabots's Avatar
2006 E55, 2006 SL55, 2006 LS7 Ute
What were the AFRs during the pulls? Cheers
Old Dec 20, 2016 | 05:44 PM
compaddict's Avatar
2016 S63, 2013 SL63
E85 is magic juice.
Old Dec 20, 2016 | 06:00 PM
rawdvm's Avatar
'04 E55 AMG
You can see them on the graph, they are the 2 bottom lines.
Old Dec 21, 2016 | 01:35 AM
jmb614's Avatar
E55 AMG
Can't wait to see what kind of times and speeds she puts down at the track(s). Congrats brotha, have fun!
Old Dec 21, 2016 | 03:06 PM
I did it myself, I'm currently running AEM 320 pumps in the stock buckets and ID1000s. No other hard part changes have been needed but I plan to convert to full return style in the near future to control pressure better than factory.
Old Dec 21, 2016 | 04:42 PM
jmb614's Avatar
E55 AMG
IIRC the AEM's are drop in, hence the reason people use them on this platform. Converting to larger injectors and fuel lines along with a return line would be optimal, just as rock is describing. Chawkins' beast was on the corn for a while, but when I talked to him at Timmayfest he mentioned it was a PITA for everyday use. Along with the tuning there other factors to consider. Is it cold outside? Have to worry about the fuel gelling up. Going on a road trip? I hope you plan your route accordingly so you don't run out of gas in the middle of the desert.
As Ahmad has asked before, Icanhasflexfueltuning, plox?
I wish
