KW V2 first impressions!
Old Dec 22, 2016 | 06:52 PM
211.070's Avatar
2005- E55, 2007 GL450, 94 B3000
I just got to drive my car today after installing KW V2 coilovers, new upper ball joints, sway bar link ball joints, and front K-Mac bushings. I already had the rear K-Mac bushings.
Wow! The ride quality is superb! I am a bit upset about the rear adjustment though. I had to compress the springs in order to adjust them higher. It is sitting a bit lower than I like, and I am pretty much out of adjustment for the rear. I am going to order a few more spring shims for the rear, and install the spacers in order to get another 10mm of height...
I Performed an alignment. I set the rear camber @-1 degree, and the front @-1.5 degrees. Toe settings were set to factory specifications. The car feels much tighter, and has crisper turn in!
All in all I am pleased with spending 4 grand in suspension upgrades! Still just want it a little bit higher in the rear.
I will get some better pictures when I get a chance.
Old Jan 1, 2017 | 02:13 AM
eightyseven's Avatar
2004 E55 AMG
The rear adjustment is a huge PITA, it isn't like that on my E46 M3 with V2s or my old E39 M5 with V2s.
Old Jan 1, 2017 | 08:28 AM
Hulk's Avatar
A Merc
I agree I have diff coilovers however I only have 1 finger gap, I would like just a tad more, will see what I can do
Where are you getting the shims for this?
Old Jan 1, 2017 | 11:20 PM
Max.H's Avatar
E55
I just noticed your thread. Car looks good. Congrats on the new coilovers! Ive been hearing some really good things about this conversion. I just did new arnotts but, if my buddies cars perform well and ride good on the Godspeed Project Mono max coilovers I will go the same route.
Old Jan 2, 2017 | 05:28 PM
211.070's Avatar
If you order the upper spring perches for the factory steel suspension car you can remove a small shim from it. It might be 2-3mm thick.
Old Jan 2, 2017 | 05:29 PM
211.070's Avatar
I love how the car drives now! It is much better than the airmatic.
Old Jan 2, 2017 | 05:58 PM
MTV10's Avatar
E55 AMG & C63 AMG
Rear ride height is perfect.
I'd leave it just like that
Old Jan 2, 2017 | 09:05 PM
Dublinoh's Avatar
E63 AMG 2007
That was my first thought too.
Old Jan 2, 2017 | 10:09 PM
Hulk's Avatar
A Merc
211 yours is perfect. Mine has about a finger gap but I run a 285/35/18. I was going to put the factory perches for the steel however I wouldn't have been able to use the adjuster on my kit..
I could prolly use the spring compressor and get another 2-3mm maybe..
Old Jan 3, 2017 | 08:16 PM
211.070's Avatar
I love the way it looks, but It was a pita getting it on, and off of the alignment rack.
I did not use the factory perches. I used the rubber insulator, and the shim that is between the insulator, and the perch. I may use another shim from one of these.
Old Jan 3, 2017 | 08:45 PM
Hulk's Avatar
A Merc
Where did you get the shims or better yet where can I get them
Old Jan 6, 2017 | 11:57 AM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Car looks like it sits pretty nice. Hard to tell without a full side pic but it looks even. Glad you like the way it rides
