70mm pulley? Who has one? Dyno numbers?
Old Jan 24, 2017 | 09:59 AM
J J's Avatar
J J
Issues? Belt slip?
Old Jan 26, 2017 | 07:06 AM
coolchuck's Avatar
2016 E63s
Im curious too. Can any of the vendors chime in as far as their performance?
Old Jan 26, 2017 | 08:00 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Do a search it's been discussed. In a nutshell it's a huge pulley and you need max cooling, tb and longtubes and injectors. anything less it creates more heat than it's worth. You will need a trunk tank and killer chiller or meth. Anything larger than a 77 your trading more heat than hp created.
Keep in mind there are cars with 83mm pulley shorty headers 82mm tb and dyno tune pulling more than 520 at the wheels. They have big heat exchangers and big trunk tanks. Cooling is more of a key than pulley size. This is more power than most with long tubes 77mm pulley 82 tb and tune with h/e and engine bay tank.
Old Jan 26, 2017 | 09:09 PM
oneslow55's Avatar
E55 amg
Don't pull up to a 77 setup cause you will be in for a shock with your 70 pulley
Old Jan 26, 2017 | 09:20 PM
Ls1toAMG's Avatar
Not Sure what you mean by that. You can ask the vets. Hulk Shardul hammer down black Benz ect the 70 mm pulley isn't outperforming a 77 without MASSIVE cooling if you think it will my 83 mm will walk you. Learn the platform
Old Jan 26, 2017 | 09:25 PM
oneslow55's Avatar
E55 amg
You clearly can't read properly !!! Read what I wrote again ,maybe you'll figure it out after .Ill say it in lemans terms for you ,a 77 pulley will walk a 70 setup on the street any day of the week.It will pull timing back after 100 mph very bad!Only way to over come this best ,will be proper cooling and e85 the it will feel like a monster ! to much cooling will have diminishing affects
Old Jan 26, 2017 | 09:29 PM
Ls1toAMG's Avatar
It's all good. I did read it properly but the laughing guy pounding his fist at the end I thought you where telling me I was crazy. Peace brother, be safe.
Old Jan 26, 2017 | 10:06 PM
oneslow55's Avatar
E55 amg
Yes ..77 is the best upper setup nothing more nothing less !
Old Jan 27, 2017 | 12:09 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Thank you sir!
Old Jan 27, 2017 | 12:18 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
We will be back with dyno numbers shortly as our car is currently down for our whipple kit fitment and testing.
on a 55 to 135 pull, IAT was 86F going in peaked at 131 and recovered instantly to 90 with the 70mm pulley with the following cooling mods VRP superflo, VRP primary (single pass version) and secondary HE, 5 Gallon Trunk tank (no ice).
This is without methanol or Ice on the stock Intercooler. we have 6 intercooler cores and they will be available as single pass units VERY shortly.
most of you are seeing the same temps on your 77mm. so pull up to a 70mm car with a 77 and see what happens. lol
We had a customer pickup 34whp from a 77 to a 72 clutched with a dyno tune.
Old Jan 27, 2017 | 12:50 PM
shardul's Avatar
Usually you pick up 15 to 20 from a custom dyno tune itself without making any hardware changes.
Old Jan 27, 2017 | 01:02 PM
SPONSOR
E55 C63
they were dyno tuned on the 77 aswell.
Old Jan 27, 2017 | 01:06 PM
shardul's Avatar
lol yeah ok
Old Jan 27, 2017 | 01:28 PM
RBM113K's Avatar
03 E55
How much for intercooler
Old Jan 27, 2017 | 01:41 PM
SPONSOR
E55 C63
the modified single pass units will retail at $700 with core.
Old Jan 27, 2017 | 02:18 PM
RBM113K's Avatar
03 E55
Is that a 3/4 in one side 3/4 out the other ?What else is needed ,gains ?
IAT diff ,that's a lot with a core
Old Jan 27, 2017 | 09:04 PM
SICAMG's Avatar
2005 e55 AMG
LS1to AMG.... Your a good man brother !!
Old Jan 30, 2017 | 09:33 AM
SPONSOR
E55 C63
That includes the core charge*
3/4 both sides, ours will be tested at the track as soon as it gets warm here. (snow on the ground in VA) But there have been some awesome results posted across the forum for similar units.
Old Jan 30, 2017 | 11:11 AM
RBM113K's Avatar
03 E55
Ok
Old Jan 30, 2017 | 12:07 PM
SICAMG's Avatar
2005 e55 AMG
Fantastic mod that I did as well but took some time with cutting and welding but really worth it to do!!! Money well spent IMO !
Old Jan 30, 2017 | 04:23 PM
RBM113K's Avatar
03 E55
That's what meant the Intercooler hoses going into the tank, you would need 4 holes no
