What do think is worn to cause this wear?
Old 02-08-2017, 11:48 PM
skylinrcr01's Avatar
2004 E55, Triumph Speed Triple
I got some really funky alignment wear on my tires, I suspect it's some sort of control arm, but they are all visually ok. Any ideas?
Old 02-09-2017, 12:25 AM
ItalianJoe1's Avatar
2003 CL 600
How were the alignment settings?
Old 02-09-2017, 12:45 AM
I haven't taken it in to get aligned yet, wear that extreme, I figured I have some bad joints, and after I replace them I'll get it aligned so I don't have to do it twice.
Old 02-09-2017, 12:48 AM
Rocman8's Avatar
E55
Normal considering you got most of the use out of the rest of the tire. These cars have a lot of camber so that's going to happen. Are you lowered at all?
Old 02-09-2017, 12:50 AM
Nope, stock air shocks. I had one blow out (front left) in the desert and had to drive home on it, so that may have caused them to wear really weird. That was 6 months ago though.
Old 02-09-2017, 12:10 PM
HeissRod's Avatar
'06 E55, '15 Jeep SRT8, '94 Mustang GT
Looks like these are rears, so that could be toe wear as well. I second the suggestion to get your alignment checked.
Old 02-09-2017, 02:03 PM
Fronts actually.
Old 02-09-2017, 05:18 PM
Dublinoh's Avatar
E63 AMG 2007
Almost looks like it's rubbing on something. Is this stock size on a stock wheel at stock height? What does the other side look like? Does the wear you pictured go all the way around the tire?
Old 02-09-2017, 06:20 PM
Stock wheel, stock height.The other side's outside is really heavily worn, and yeah, the weird way wraps around the tire. I'll snap a picture of the passenger side when I get home.
Old 02-09-2017, 06:39 PM
FunkTron's Avatar
2006 CLS55
based on how the wear bars are even all the way across, i'd say something was rubbing on this.
have you taken a look inside your wheel well yet?
Old 02-09-2017, 08:28 PM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
Common on w211s
If the car is lowered the wear will be accelerated
HeissRod (02-09-2017)
Old 02-09-2017, 09:08 PM
Dublinoh's Avatar
E63 AMG 2007
You had a left air shock (which is the "spring") "blow out" so you drove home with the left side much lower, right? And this is the right front tire with wear on the inside, but the left front has wear on the outside, right? I don't think this a wear pattern due to worn components, this is damage caused by driving with the ride height too low on the left side. Have you looked for damage or wear inside the fender wells? Or was the car pulling very hard to the left and you needed to steer hard right to go straight? Either way I think you can safely get new tires and an alignment.
Old 02-09-2017, 10:10 PM
layzie12g's Avatar
2008 Mercedes Benz E63
These cars wear the inner edge no matter what you do. It really sucks.
Old 02-10-2017, 07:17 AM
StarvingArtist's Avatar
CLS 55 AMG E500 99 ML320
My tires used to look like that on the inside edge after 5000 miles.
After 6k in tires and alignments in two years I finally took matters into my own hands.
I run K-mac bushings in my front thrust arms, and slotted the subframe for the front control arms. I was going to put adjusters in the slots, but ended up slotting until I had the camber where I wanted it, then locking it down and forgetting. I also run a K-mac kit in the rear for the last 60,000. If it ever fails I will build custom control arms and toe links.
I built a wooden jig to do my own alignments. No more uneven wear. I get around 30,000 miles out of them and still have tread left. Problem solved. Should have learned quicker.
HeissRod (02-10-2017)
Old 02-10-2017, 08:01 AM
Dublinoh's Avatar
E63 AMG 2007
True, but his left front has wear on the outside edge?
Old 02-10-2017, 01:05 PM
thtguy's Avatar
2004 E55
Looks like classic toe wear to me
Old 02-10-2017, 04:13 PM
HeissRod's Avatar
Post pics of the other front tire for comparison
Quick Reply: What do think is worn to cause this wear?
