E55 Restoration
Old Sep 13, 2017 | 11:28 PM
  #76
Harambe's Avatar
2003 e55
Originally Posted by driffydre
Can I bring mine and you do the exhaust? Absolutely admire the dedication to detail and quality work you putting in to get her right. I can't wait to get started on mine.
Thanks. I don't think I'll be doing another one of these exhaust systems though, it was a lot of work. I do more maintenance type work, then fabrication work. There are some other places in the area that can definitely build you a high quality exhaust system.
This is my ideal day:
Old Sep 18, 2017 | 11:42 AM
  #77
Harambe's Avatar
2003 e55
Made the brackets to put the ballast on the oem position
Mocking up the intake. Need to weld some brackets on and attach the scoops.
Old Sep 23, 2017 | 06:06 PM
  #78
Harambe's Avatar
2003 e55
New headlights and intake all finished up. Put a new steering wheel on and replaced the torn mirror gaskets.
Old Oct 1, 2017 | 12:29 PM
  #79
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
I like the intake air setup. I will be fabbing one similar for CLK with less real estate. Are the filters located in the pipe near supercharger or fitting in the intake air plenum out front?
Id like to find a filter setup if located under hood, Y pipe @ throttle body is a mystery as well.
My MAF will give me an edge here.
Thanks for posting this car.
Best Gator
