Eurocharged gets 643 whp out of the W211 E55 AMG
The W211 Mercedes E55 AMG may be fourteen years old at this point but it still continues to impress. When Mercedes-AMG threw a 5.5 liter V8 (M113K) into an E-Class chassis and supercharged it, they sent a message. Look at how capable the M133K motor still is today.
Setup:
2005 E55
Stock Motor
Stock Heads
Stock Cams
Stock Trans (at the moment)
Fuel System:
2x Walbro 450cc in the factory baskets
Custom Fuel Lid for Passenger's side
-10AN from tank, through external FPR and Filter
Split factory rail with -6 inlet on each
Mods - FBO
American Racing Longtubes
90mm TB
178mm Crank
77mm S/C Pulley
650cc Injectors
Eurocharged ATX Flex Fuel
We are talking bolt on modifications with an upgraded fuel system for ethanol. Nothing crazy there yet the engine design which is well over a decade old is showing 643 horsepower to the tires.
They plan on doing some further tuning with higher ethanol contents but suffice it to say the W211 E55 is an all time great.
Full Article: http://www.germanb??st.com/content.p...g-and-bolt-ons
If you want to be a dyno queen, then you are the KING! SMH!
http://www.***********.com/showthrea...g-and-bolt-ons
They're both the same link.
It's not only for the dyno, DON'T WORRY - we'll keep you all posted!
Dave
Dave
Dave
Stock Engine, Stock Heads/Cams, Stock Supercharger. 70% Ethanol (E85 from the pump). Tuned by Jerry @ Eurocharged.
I am curious how bonkers you can go on the W211 while still keeping it as a (partial) DD.
Obviously it goes without saying that there are certain things that are different. It's a lot louder...the solid engine mounts transmit a little more "feel" into the cabin (still not bad at all). Trans shifts harder, fuel pumps are louder.
Other than those things, its still an Airmatic car, all stock suspension. Still a 722.6, and still has a clutch on the S/C pulley. so really, if you want to putter it around, you can... It just has loads more power when you want it.
SO if we go by pure driving characteristics, I'll give it a 8. If we go by everything, a 6. Average to get a 7. Overall, I'd say it drives pretty much the same as a car with : Tune/83/LTH. Something like that.
Dave
2. Yes, the flex system we sell uses an ethanol sensor.
Dave
