Attn: T-Bone!
Old 04-12-2004, 06:00 PM
EX-BEEMER's Avatar
'08 SL550 Sport, '11 BMW 550ix M sport
Attn: T-Bone!
Hey T-Bone,
Loved your Sat. Radio install! I'm taking my car in Thurs to have my radio installed. Do you have any picts of your mounting bracket underneath your rear window deck?
It would be a big help to my tech guy...
Any help you could give me would be appreciated.
Thanks,
Tony
Old 04-12-2004, 06:17 PM
t-bone's Avatar
2004 E55
been real busy the last few days.
i'll try and snap some pics tonight.
Old 04-12-2004, 06:44 PM
EX-BEEMER's Avatar
Thanks Man!
Old 04-12-2004, 06:51 PM
Kens-E55's Avatar
2004 E55
T-Bone
I see you have an E-55 with Renntach upgrade? What Renntech mods did you do and how noticeable were the upgrades in performance. I'm in West Palm and looking to go with Renntech. Thanks for your input.
Kens-E55
Old 04-12-2004, 08:15 PM
t-bone's Avatar
2004 E55
Originally posted by Kens-E55
T-Bone
Kens-E55
Here's a thread that I responded to a while ago regarding my Renntech upgrade.
Other people chimed in too.
https://mbworld.org/forums/showthrea...threadid=61037
I also got the Renntech steering wheel:
and the Renntech rear spoiler:
Old 04-13-2004, 02:17 AM
t-bone's Avatar
2004 E55
here are the pics
Ok... so here are the pictures of the antenna.
Here is the antenna. It is on the left side. If you take a look underneath the rear deck you will see where it went. You can see the wire that leads to it. This wire had to be rerouted from the trunk lid back into the trunk itself.
Here are two more from different angles.
A hole had to be drilled into the metal to mount the antenna. I have black felt tape that covers the wires, but I removed it for the photos. The wires are zipped tied together.
As you can tell it's a HUGE *** antenna. I could never mount this on my trunk. It would just be an eye sore to me. I'm not sure how people will get used to it being on the trunk lid. I'm glad I don't have to.
Reception is great. An amazing selection of stations.
Reception is only lost when something blocks the antenna from the sky. As long as the antenna has a direct line of sight to the sky, then there are no problems. Like I mentioned before it has a buffer of a few seconds to allow you to travel under bridges and large trees without the signal being lost.
Old 04-13-2004, 08:55 AM
EX-BEEMER's Avatar
Excellent T-Bone!
Thanks so much. I'm emailing these to my MB Tech today.
You've been a big help.
Tony
Old 04-16-2004, 04:38 PM
EX-BEEMER's Avatar
T-Bone...
Had my Sirius radio installed today, per your installation method...works great!
My dealer was so impressed with your method, he said that all future E class installs will be done that way. (he hated the idea of drilling into the trunk lid too)
Thanks T-Bone!
Old 04-16-2004, 04:40 PM
t-bone's Avatar
2004 E55
No problem. Glad to be of help.
How long did your service guy take to do it?
What did your total cost end up being?
Old 04-16-2004, 05:38 PM
EX-BEEMER's Avatar
Radio was $675
Labor was $250 (I'm pretty sure I got hosed) 5 billable hours
Too much for a radio they'll be giving away in two years!
P.S. Love the new wheels BTW!
Old 04-22-2004, 10:36 PM
lcrngrs's Avatar
2004 e320 4matic
t-bones installation
Hopefully within the next few days I will be installing Sirius radio the "t-bone way". I went to my dealer with the pics and he said he should be able to do it. I also called t-bones installer today and he was more than happy to help. I'm not sure how much my dealer will be responsible for if it doesn't work as designed. They are giving me some crap about the warrenty being voided because It's not in the "recommended Mercedes spot", but I'll have to see what happens. I'ts costing me 1000.00 which seems to be the going rate here in NJ. Anyone else have this done this way yet and if so, are you happy with the results. thanks.
Old 04-22-2004, 11:20 PM
t-bone's Avatar
2004 E55
haha "the t-bone way"
Old 04-22-2004, 11:43 PM
lcrngrs's Avatar
2004 e320 4matic
the t-bone way
Glad you got a kick out of that one. Just curious, on a scale of one to ten, where do you rank your reception with 10 being excellent. Do you have much interference or lack of signal? thanks
Old 04-24-2004, 08:50 AM
RoadRanger's Avatar
2004 E55 AMG Black/Charcoal/Burl Walnut
Thanks for the advice My dealer did the install just as you showed and it works great. Needless to say there going to recommend this to all new customers
Just picked up my car and its UNBELIEVABLE
Old 04-25-2004, 10:24 PM
lcrngrs's Avatar
2004 e320 4matic
installation
Monday is almost upon us and I'm still trying to find out specifics about how good reception is using the "t-bone" way. I will be getting this done very soon and would really appreciate a response from t-bone or roadrunner. thanks again
Old 04-25-2004, 10:29 PM
t-bone's Avatar
2004 E55
I find no problems with reception except when I go under bridges or large trees. Sometimes it won't even cut out at all when going under bridges. However, going under bridges repeatedly will use up the buffer so switching stations rebuilds the buffer.
If it does cut out, it will cut out for maybe one or two seconds then come back. It doesn't bother me that much.
The reception is either yes or no. There is no in between like FM or AM radio with static.
I also have no frame of reference to compare my reception to though. All I can say is that I am very happy with it and that there are is an amazing amount of stations.
There are even some comedy stations.
The "t-bone way" is the only installation way to go.
Old 04-25-2004, 11:15 PM
RoadRanger's Avatar
I also find that when I drive through a cluster of large trees, or am in my garage, that the signal cuts out. Other than that there have been no issues with reception.
Old 04-26-2004, 01:10 AM
lcrngrs's Avatar
2004 e320 4matic
Smile install
Thank you very much for the info. You have given me some piece of mind which has been a great help. I'll keep you posted on my results. thanks again
Old 04-30-2004, 03:06 PM
Barry45RPM's Avatar
2015 ML 350
Voice Recognition Comands
Does anybody know if there are voice commands that the Satellite radio will understand? On regular radio (AM or FM) you can switch stations by voice. When I pull the voice stick on the side of the column, I get a picture of a microphone and a phrase something like "Application?" is displayed.
Old 05-06-2004, 09:23 PM
04E55 AMG's Avatar
04E55AMG, 05Dodge RAM 1500 Quad Cab, 02Montero Limited
Just picked up my car from the dealership today. The T-Bone way works great. The sound is AWESOME with the LOGIC 7 system!
Thanks T-Bone and Ex-Beemer for your help.
Parts were $692.30 and the labor was another $400. Dealership told me that they will start installing all E series this way. They had done a SL55 the other day and drilled holes into it...OUCH!
Maybe on the SL since the roof retracts, drilling is the only way.
Spero
Old 05-07-2004, 05:23 PM
lcrngrs's Avatar
2004 e320 4matic
Thumbs up the t-bone way
Finally got my install the t-bone way and so far so good. I'm absolutely thrilled! My dealer did however emphasize that this was a one time thing and would not do it for anyone else. Supposedly they had to beg the manager to do this for me. Anyway, I'm glad to have found this site and cannot thank you enough. It sounds great too! Now all I have to do is figure out how to use it. ha ha, thanks,
Lou
Old 10-22-2009, 08:02 PM
GeoBarbD's Avatar
2006 E500
Antenna Install
Could someone please post copies of the pictures of this install. For some reason I can not get at the ones T-Bone posted here in this string.
Thx--George Des
Old 10-22-2009, 08:22 PM
t-bone's Avatar
2004 E55
DANG! This thread is old.
Those pictures were on a server that I no longer have access to.
I'll have to see if I can find them, but I think they are gone.
I'll try and get some photos the next time I'm back in Cali which will be in about 2 weeks.
Old 10-22-2009, 09:04 PM
Administrator
Vic55's Avatar
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
WTF 5 year thread revival!!!!!!!!
Old 10-22-2009, 09:21 PM
GeoBarbD's Avatar
2006 E500
Antenna Install
T-Bone. Thx
George Des
Quick Reply: Attn: T-Bone!
