tuned e55 slight lump in idle
Old May 9, 2017 | 01:59 PM
alenpepic's Avatar
2005 CL55 (sold) C63 Coupe 2012 p31(sold) Audi 330awhp E55 511WHP(sold)Z06C6 550whp C63 LTH
Bought a OBD2 to check it out, all i got was errors for not having the Secondary O2 sensors in but im pretty sure thats not causing this issue. I couldnt find any leaks and it is not showing up as a code, should i clean out my throttle body?? even if it doesnt show up as a code. its a minor lump in the idle and it only happens in park and neutral. Car runs real good.
Old May 12, 2017 | 01:52 PM
BoostedAero's Avatar
2004 E55
Gonna go plugs on this... how long since you swapped?
Old May 12, 2017 | 10:03 PM
alenpepic's Avatar
put in brand new NGK one step colder plugs, car was fine till I did the spark plugs and went catless it was done in one shot. The tune didn't knock it out. I'm assuming it's maybe the throttle body needing to be cleaned. But I didn't have this problem till I brought it to do do this work.
Old May 13, 2017 | 02:22 PM
Pinned's Avatar
E63 AMG
Is there a reason you're running one step colder? Try swapping back to stock plugs and see what happens.
Old May 13, 2017 | 05:35 PM
Hulk's Avatar
A Merc
By lump do you mean like a slight misfire at idle?
How many miles on your car?
What mods etc?
Old May 13, 2017 | 06:12 PM
oneslow55's Avatar
E55 amg
If the car has one step colder plugs and headers then you could a expect a slight Little Rock type feel that Avery minor when parked as long as you got no codes miss fored and runs strong your good to go
Old May 21, 2017 | 04:11 PM
alenpepic's Avatar
Yes exactly how u explain it, thank you.
Old May 22, 2017 | 05:29 PM
MACEDON's Avatar
05 E55, 98 CLK320
I even googled it to find out what you mean but I don't get it... little rock feel??
Old May 23, 2017 | 01:55 AM
PieRat's Avatar
CLS55
A intermittent ever so slight shudder of mine is anything to go off. By intermittent I mean its smooth, shudders slightly back to smooth then small shudder. I guess? Description words lol
Old May 23, 2017 | 09:52 AM
MACEDON's Avatar
05 E55, 98 CLK320
Yeah that makes sense. Mine shakes consistently like a muscle car (which it is a muscle car really lol)
Old May 23, 2017 | 10:57 AM
alenpepic's Avatar
It's bc of the headers I'm pretty sure but the spark plugs too, I have no CEL for misfire so It's just a normal hiccup I'm assuming. My car idle fine and when I did the spark plugs and catless headers(one shot) it gave me the slightly rough idle. I would've cleaned my throttle body and MAF sensor but if it was good before this why would I. So I'm gonna go with tuning to ease the hiccup but the car drives 100% normal no hiccup it's the idle in park
Old May 23, 2017 | 11:16 AM
oneslow55's Avatar
E55 amg
Yes,very normal after headers more some L.T it's just getting so much more flow now.
Old May 23, 2017 | 11:18 AM
oneslow55's Avatar
E55 amg
Normal with the headers as mentioned dozen times.This the joys of modding your car,it won't feel and be like stock anymore.The colder plugs,will attribute to this too ..
Old May 25, 2017 | 08:35 AM
alenpepic's Avatar
lol im gonna slap the 77 and the injectors and fuel rail lmfao hiccups are only gonna get worse
Old Feb 21, 2018 | 12:21 PM
Faster_Gun's Avatar
2003 E55 AMG 2001 911 Turbo
Just wanted to comment I have a similar rough idle after going to Eurocharged headers. I can't tell its rough until I turn the stereo off and really feel for it. I eliminated my primary cats while doing the headers.
No CEL for misfire.
In chasing this rough idle condition down I replaced the following with no change:
Lemforder motor mounts x2
Lemforder transmission mount
Bosch Sparkplugs FR6MPP332
Valve cover gaskets - checked crank breathers for poor connections
Confirmed okay plug wire resistance
Had I not found this thread I would be taking a good hard look at my coil packs but the car pulls hard.
I will probably replace the pulley and tune once the weather warms up.
Old Feb 21, 2018 | 12:24 PM
alenpepic's Avatar
Im beginning to think that idle is just something we have to deal with or the fueling is off, maybe pumps are not giving enough gas to support the setup
Old Feb 21, 2018 | 01:37 PM
oneslow55's Avatar
E55 amg
No CEL for misfire.
What happens is the engine breath harder making the light shake at times.
Also ,carbon build up and dirty fuel system can do this too.
\Some m113k setups just idle this way ,as long as it's not ruff in drive it's fine.If you want silky smooth idles stick with a Honda or so..
Old Feb 28, 2026 | 09:00 AM
brsilves's Avatar
E550
Not sure if my previous reply got posted. I scrolled up and saw you have headers. Go to a shop and have them disable your downstream O2 sensors. Get a new upstream sensor. Dont expect your sensors to last more than a year. The optimum placement for O2 sensors is a max of about 12" from exhaust port. Yours are (probably) 24-36" away. That leads to variations in readings, more variability in exhaust readings and in general, more variables introduced into the AF ratio.
Old Feb 28, 2026 | 09:33 AM
danil_karmiev's Avatar
E55 AMG
