VRP heat exchanger oil cooler remount
Old May 12, 2017 | 12:21 AM
CDC55AMG's Avatar
CLS55AMG
Hello all, I am planning a VRP V2 heat exchanger installation soon and had a question as to where or how those of you have remounted the factory oil cooler. I will be doing a split cooling and Bosch 010 pump upgrade on my 06 CLS 55 AMG as well. Also any tips on front bumper R&R?
Thank you in advance!
Old May 14, 2017 | 05:42 PM
SICAMG's Avatar
2005 e55 AMG
I took my cooler out. Not needed with how I drive and gave me plenty of room with out it there.
Old May 15, 2017 | 09:14 AM
hayseed's Avatar
04 e55
I was thinking the same thing -- with 9 qts of oil do you really need a cooler unless your driving cross country @ top speeds ?
Old May 15, 2017 | 09:39 AM
SICAMG's Avatar
2005 e55 AMG
Well mine has 2 coolers and one has a fan on it so that cooler on the bottom served no purpose for me.
Old May 15, 2017 | 10:58 AM
BoostedAero's Avatar
2004 E55
Interesting, very interesting....
I drive 20-40 miles at a time. Mostly putting in traffic. Every week or so it gets a highway beatdown for about 5-10 miles.
About 1-2x a year it goes to the mountains for some spirited driving getting its *** kicked by my brothers tuned 335xi
Wondering if I can ditch the spare cooler as well....I hate its location and how I have it mounted...hmmmmmm
How much driving do you do with just one oil cooler Gary?
Old May 15, 2017 | 12:20 PM
CDC55AMG's Avatar
CLS55AMG
Hi guys, how are you capping off the oil cooler under the heat exchanger? I am pretty new to the M113k engine and Mercedes as whole so my other question is how many oil cooler does this engine have? Those of you that have the VRP heat exchanger are you in favor of it and what was the deciding factor over the PLM heat exchanger? Thank you!
Old May 15, 2017 | 12:24 PM
SICAMG's Avatar
2005 e55 AMG
Lots and oil temp is not a problem. Engine temp is at 180 so oil is even cooler without an engine running at say 190*. An oil cooler with a fan on it is more than enough so that dumb *** cooler on the bottom had to go. I will be running a roll race 1/2 mile event and will give even more feedback from that if you need it.
Also the other reason for ditching it was my secondary cooler is behind the driver fog light,that has been removed,so the 3/4 cooling lines to the cooler needed some room to run across underneath.
Old May 15, 2017 | 03:09 PM
oneslow55's Avatar
E55 amg
Vrp exchanger is to heavy too..I don't get why no one does mount setup like plm does .This why I like the plm kits there got too notch welds and tanks are quality ..
Old May 15, 2017 | 04:01 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
We sell a lot of PLM HE.
At $350 shipped they are a bargain for poeple who are looking for a bolt on solution.
Old May 15, 2017 | 05:49 PM
f8l ws6's Avatar
2005 E55
I've got a PLM myself. I love it because it just bolts on, no drilling or tapping required. Also comes with the brackets to mount the lower cooler.
Old May 16, 2017 | 05:25 AM
CDC55AMG's Avatar
CLS55AMG
When I asked vrp if they had any bracket kits for oil cooler like plm they stated no and that I would have to cut off my old brackets and have them welded onto the VRP unit. When I asked the difference between the two cores they stated theirs was the biggest but offered no objective details. Will the PLM unit new fit on the CLS 55 as well as the E55 it was designed for? Such as bumper clearance and brackets lining up for bolt holes etc. I get this is an E55 forum. Thanks all for your help! Shardful I will be in touch if I decide to go with an upgraded heat exchanger.
Old May 16, 2017 | 05:52 AM
PieRat's Avatar
CLS55
Im pretty sure cls55 has more space for HE than e55.
Old May 16, 2017 | 06:00 AM
shardul's Avatar
Yes the PLM will fit without any issues on a CLS
Message me if you want one.
Old May 16, 2017 | 08:56 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I think that removing your coolers, might be a big mistake. Do you really think that you know better then the AMG engineers who design and built the engine. They added these oil coolers for a reason. I just hope that you don't regret removing them in the future.
Old May 16, 2017 | 09:43 AM
hayseed's Avatar
04 e55
I agree to a point, but those same engineers designed the intercooler that really is too small to cool sufficiently or recover quickly - autobahn running an oil cooler maybe needed to help cool oil but @ 80 mph/2000 rpm not needed - lower IATs will keep heat down and maybe better choice
Old May 16, 2017 | 09:47 AM
oneslow55's Avatar
E55 amg
Buy a plm and not deal with zip ties or even removing coolers
Old May 16, 2017 | 09:04 PM
PieRat's Avatar
CLS55
What relation do engine air intake temps have to transmission oil temps?
Old May 17, 2017 | 07:04 AM
hayseed's Avatar
04 e55
I believe this is an engine oil cooler 1 of 2
Old May 17, 2017 | 09:14 AM
AgSilver's Avatar
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
Do not remove the oil cooler. Oil cools everything it touches.
Old May 17, 2017 | 09:54 AM
2004 E55
https://media.giphy.com/media/MTpTfPUCgyEzS/giphy.gif
Old Aug 2, 2017 | 01:19 AM
WKELLY's Avatar
SL55 AMG
PLM HE
Is the PLM HE a bolt on solution for an 03 SL55 AMG? I was also looking at the VRP Speed V2 HE. Looking for one that requires only minimun mods to be done. Thanks!
Old Aug 2, 2017 | 10:59 AM
shardul's Avatar
If you look in the SL55 section you will see a post / DIY from a member regarding the PLM HE install on a R230 SL55
Old Aug 2, 2017 | 11:59 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Here's my install of the PLM heat exchanger on my W211 E55. I bought it from Shardul; it's a good deal.
https://mbworld.org/forums/mercedes-...formation.html
Old Nov 4, 2017 | 04:22 PM
Plataille's Avatar
E55
VRP sells the PLM units aswell.
Old Nov 4, 2017 | 04:39 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
Bahaha, you're killing me man. You literally just did a search of VRP threads you could bump didn't you. Hahaha.
