W211 SOS and telephone antenna splitter maintenance
Old May 28, 2017 | 03:25 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Lately, I've been getting a message stating "SOS malfunction". I have read this is most likely caused by the antenna splitter suffering corrosion.
I've attached photos of how to locate the splitter, remove the antenna leads, the corrosion I found, and how I used a brass wire brush to carefully remove the corrosion using high-quality electrical contact cleaner/lubricant.
Removing the upper connector from the trunk lift mechanism will give you a bit more room. The antenna splitter is held to the sheet metal with two plastic "push" clips. I broke one off so upon reinstallation, I used a nylon tie-wrap to steady the splitter to another cable harness.
The plastic clips for the two lower cables remain on the splitter and you pull the cables out. The plastic clip for the upper cable remains on the cable. The photos show you where to apply the needle-nose pliers to release the clips.
The antenna splitter had serious corrosion on the upper connection. Generous applications of contact cleaner while carefully rotating a brass brush around the inside of the barrel will remove the corrosion. Be sure to blast out the remnants with a good shot of contact cleaner.
Hope this helps someone.
Update: Definitely a leak. Driver's side trunk gasket was not seated properly and water was seeping in in heavy rains.
Attached Thumbnails W211 SOS and telephone antenna splitter maintenance-dsc04900_resize.jpg   W211 SOS and telephone antenna splitter maintenance-dsc04898_resize.jpg   W211 SOS and telephone antenna splitter maintenance-dsc04896_resize.jpg   W211 SOS and telephone antenna splitter maintenance-dsc04894_resize.jpg   W211 SOS and telephone antenna splitter maintenance-dsc04892_resize.jpg
W211 SOS and telephone antenna splitter maintenance-dsc04891_resize.jpg   W211 SOS and telephone antenna splitter maintenance-dsc04893_resize.jpg
Old Jan 23, 2020 | 11:29 AM
e350forme's Avatar
fleet
is this in the trunk of the car?
Old Jan 23, 2020 | 11:53 AM
JakeAndBake's Avatar
2005 E55 AMG
Just started getting this message the other day and was curious on a solution. I’ll have to check it out! Birdwell to the rescue again!
Old Jan 23, 2020 | 12:01 PM
e350forme's Avatar
fleet
he logs on so we should hear from him soon.
certainly worth checking out before I try and politely explain problem at dealership and have to charge the credit card for star services
Old Jan 23, 2020 | 12:11 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Driver's side trunk (left hand drive) behind the trunk lid hinge.
Old Jan 23, 2020 | 12:18 PM
2005 E55 AMG
Fantastic pictures. Often times very difficult to discern location and details. Thank you!
Old Jan 27, 2020 | 05:14 PM
e350forme's Avatar
fleet
Any idea where it can be in a w210 wagon?
Old Jan 27, 2020 | 09:52 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Negative. Cannot help you on this. WIS would help. Light the Konigstiger signal!
Old Jan 28, 2020 | 10:01 AM
e350forme's Avatar
fleet
it looks like most of wires in trunk of wagon are on passenger side, even then, everything is crammed together.
however, I saw a youtube clip explaining to help with SOS malfunction, to pull the "i" info switch, located by where the original cellphone was connected. so I pulled this harness, and so far have not gotten an SOS error while driving....lets hope it lasts
