Are your OIL COOLER LINES leaking?? Here's the fix!
Couple quick sketches...
Just trying to figure out who might be interested. I'm also working on the other end (with the ball seat/nut) and it will also have a -10AN on it.
This will allow for fitting of all sorts of different oil coolers, easily having your own lines made with whatever style hose/fitting combos you want. It will be easy to replace individual lines and MUCH less expensive if you ever need to replace them.
Lemme know
Pricing will be $269 Shipped for the main 4 pieces, and $299 shipped for the remaining 2 pieces to do the cooler-to-cooler line.
Dave
Besides the parts being expensive...The stock lines are a real hassle to actually replace. If you do it yourself, plan on spending at least a few hours. Expect a shop to charge the same. With the adapters, you will save a lot of time on the installation side. My goal is to have you able to buy ALL the parts - Adapters, Hose, Fittings, Clamps, everything, for around (hopefully less) than the lowest online price.
Thanks!
Dave
?!?!? Would like a few people to get it rollin'.Thanks
Dave
Let me know if you're interested - Shoot me a PM
Dave
I took my pieces in to a seemingly reputable shop for tig welding, The proprietors claimed mig welding would work fine. I ended up with a lot of leaks.
Sealed them up with silver solder and brass in stubborn pin hole leaks. They are sealed but will eventually crack and cause more problems.
I cannot post photos in the PM section so I will post them here for the world to see and hopefully learn from my grief.
some of the photo is cropped off but there is around 12 mm clearance to the radiator
55 to 60 mm will work fine
Will pm availability and billing.
Cheers, Gator
Happy Fathers day folks
They are ready to build though. I ordered a set to keep my Benz reliable but fitment might cause a 10mm return. They are working to try. well see.
Lets Benz
What would you recommend? Are these parts you plan on keeping in stock? Hoping that the fuel pump assembly lid, and these fittings, will be available for a while, because when the time comes I'm hoping to not have to use stock parts for em.
I should have a pile of them in a week or two, and I would like to make up a working model on a car that everyone can see, to get ideas of what it's gonna fit like, look like, etc.
I usually don't commit to have tons of stock on hand, mostly because my shop isn't really in the Mfg. business... just designing solutions for stuff I see, and making enough to be cost effective... If there is enough interest, I can make larger runs
The next round of lids should also be done pretty soon!
Dave
OK FOLKS! Got em' in my hands and did testing today - Fitment is perfect, and they have a nearly identical "stick-out" from the filter housing. Seals with the factory o-ring. Installed and ran them on a car I'm parting out and its perfect!
Posted some pics to allow ya'll to see them in action.
Thanks,
Dave
that's good to know Bro.
My project continues. Haha.
I am out of crutches and on a cane. Car is close to the bolt e-sc. I will post the results from the cooler fittings for CLK readers.
W211 folks should be fine.
All the Best, gator
