Help me keep my car
How much time has elapsed? My dealer jumped straight back in when the transmission lines came out of the radiator not long after transmission rebuild and made a mess everywhere. I was happy paying consumables and a small portion of the replacement fluid.
Where you went wrong is putting autozone motor mounts in the car. Not saying that some of the cheaper stuff doesn't work but motor mounts are less than $280 and that's OEM. You have to remember these cars are heavy and have a lot of torque. That oil line is EXPENSIVE AF. I forget what i paid i think it was like $500 or better and it had to come from Germany. I am wrench savvy and had a friend help me who has his own shop and that line is difficult to install, difficult meaning it's annoying and time consuming to get it to route correctly. Put oem mounts on the car and replace the oil line at an Indy mechanic if you don't want to tackle it. You may be able to take the line off and take it to a hose shop and have them fix it. Good luck man
Ask him if he has any of the AN fitting oil filter housing lines left. If you can get some your life will be a bunch easier.
I had had a busted line as well, I can see excess vibration causing too much stress on the pressed on fitting on the barb and could see that causing a leak.
The hoses are about $278-378ish new OEM if you cannot get the AN fitting ones from Dave.
Do not spend that $ at the dealer if you have done motor mounts... you have the ability, change that line man!
There are a lot of rubber hose sections in the stock lines. Where do they leak? To me it seems there would have to be a huge amount of engine movement to break them or the fittings are a poor design...?
okay new problem. Strapping down the motor mounts seems like a GREAT idea but i tried and tired yesterday and there really is just no room.. so i agree with the other member, there doesnt seem to be a good way to strap it down. But i have an idea
^^^ this was the first set i broke when i first got the car.
I was looking and if i were to run a rachet strap on the driver side supercharger bolt, i could even fit a 2 inch thick rachet strap down the side and even clear the exhaust manifold.
And simply hook the bottom of the frame. I took a picture last night and u can see where my strap is hanging.
https://mbworld.org/forums/w211-amg/...ml#post6769579
