E55 Biggest Tires?
If you keep the stock rims, I agree 275s are the largest and 265s are the best choice. With wider rims and the proper offset, I have read reports of 285s being used but that they stick out a little and have a rubbing potential.
). I am running 275's now on my E500 w/ the AMG wheels. The tires are brand new SO-3's. I would hate to not be able to use them. Would the 275's be that tight?
255s from an R230 SL seem to fit fine on front, with the matching 285s on the back. They are a bit tall but it seems OK.
(Of course, tire manufacturer is going to make a huge difference as to what really fits... so check your manufacturer specs instead of "calculating" the size.)
-s-
I plan to stick with the stock rims!
Chill, when is the next event you are going too? Sebring?
OK, I am now considering going to 19's. Any more sugestions?
OK, I just ordered HRE 547's in black for my car. Here is a bad PS proof. What do you think? Too much?
285's will fit since someone on this board runs 9.5" rears from a new SL55 with 285's. The question remains will 9 " fronts with 265's rub. Blocktrader says no but he hasn't driven his car hard with the rear wheels mounted in front. For my next track session I will probably run with 265 R compound slicks mounted on 9" AMG stock rear rims used in the front. Hopefully this will decrease understeer.
With a 35mm offset you should be OK, with the outside of the tyre, but have a close look to see if the inside is close to rubbing anything.
Benzoboi
You only need to run a 30 profile tyre with 20's, 35 profile is correct for 19" rims on the front with 30 profile on the rear.
It's been done by a few owners with no problems so far, but none have had their cars at a race track.
Benzoboi
My car runs 255/35/19 with a 29mm offset rim. The car could easily run a 35mm offset with no rubbing inside. Depending on the amount of deflection allowed a 265 may work. Even though it looks fine on full cornering load deflection in the bushings may allow the tyre to rub the side of the top link. It will be very easy to see if this happens though.
I am now thinking of selling my front Brabus rims and putting another set of rears on the front with 265 tyres.
Any reason why I couldn't use 275/35/19 in the rear rather than 30's?
