What's the best pulley for road racing/track use?
Old Aug 30, 2017 | 10:59 PM
justinwrock's Avatar
Ducati
Anyone here track their E55? If so, what pulley are you running? If not, what are your thoughts on the best pulley setup for spending 30 mins on the track? I was originally leaning towards a 77MM pulley, but after doing some reading - think I might have issues with high IATs here when the ambient is 80 or higher... I'm now leaning towards an 83MM with a DTK heat exchanger just to be safe, but I'd like to hear your thoughts...
Thanks!
Oh, also worth mentioning - I'll also be installing EC Mid-length headers!
Old Aug 31, 2017 | 01:39 AM
951turbo's Avatar
O3 & 05 E55 Alabaster White
If I was to do what you're doing and trying to track the car, I would stick with the stock pulley and improve the exhaust side. Long tubes and good cooling mods. If you want to do a pulley then nothing smaller than a 84mm.
Old Aug 31, 2017 | 09:33 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
77mm with headers you should be fine.
Old Aug 31, 2017 | 02:24 PM
AMG_Adon's Avatar
05 E55
what shradul said 77mm and headers u fine i love it night and day difference
Old Sep 1, 2017 | 03:24 PM
DiegosAnotherR1's Avatar
e55
would the stock cooling work well with LT headers and 77mm?
Old Sep 1, 2017 | 04:01 PM
PieRat's Avatar
CLS55
I had some trouble with stock cooling and 77mm/midlengths. A upgraded heat exchanger made them go away.
Old Sep 1, 2017 | 06:29 PM
Davednconfused's Avatar
2005 E55 AMG
Thanks!
I do NOT recommend the DTK heat exchanger. It's essentially a modified used radiator. Quality is horrible. Fitment is horrible. My top two choices would be PLM or Eurocharged.
Old Sep 2, 2017 | 11:02 AM
buffyclk500's Avatar
clk500
U say dtk is bad
But have u uses it
Old Sep 2, 2017 | 11:06 AM
2005 E55 AMG
Originally Posted by buffyclk500
U say dtk is bad
But have u uses it
Yes, I own one. The quality and fitment are so poor that it shouldn't be allowed to be sold. It's just a bunch of cheap parts welded together. There is also no actual proof that it cools any better than other aftermarket H/Es.
Old Sep 2, 2017 | 03:16 PM
principledchiro's Avatar
2006 CL55 AMG
77, 74, or 72mm clutchless pulley?
77mm, 74mm, or 72mm clutched pulley?
2006 CL55 AMG; primarily for New York State street and highway racing.
Have: tandem heat exchanger, Bosche10 pump, stock intake with K&N filters, TCU tune, Kleeman mid-length headers, 200 cell primary cats, deleted secondary cats w/deleted CEL, deleted resonators, stock mufflers.
Future: 82mm TB
Old Sep 2, 2017 | 09:21 PM
clk500
Well if u were in fl I would buy it off you
So I can try it out
Old Sep 2, 2017 | 09:44 PM
Tavs's Avatar
2004 e55
I just want to clarify your comment. You are saying that there is no proof that it cools better then other aftermarket heat exchangers. This would infer that is does cool better than the stock unit, as good as other aftermarket units, just not "better" than others. You are also stating that it is "cheap parts welded together" that perform as good as other units at a lower price point with no other set backs other then cosmetic.
I am just trying to keep in perspective all the options at all the price points. I have several parts from DTK and UPD and have run with tunes from a "can" from a common tuner and what i would consider THE tuner. I have been around this car scene for years and I am always amazed that the guys that have some user or opinion induced issue are always the vocal ones.....
AdamT
So what was the issue?
Old Sep 2, 2017 | 11:01 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
AdamT
Condescending much? Haha.
Apparently the "issue" (like how I throw random words in quotes to add a condescending under tone like you did) is that he thinks the quality and fitment is poor. If you are interested in more details from his opinion on the unit he owns, you can probably ask it in about one sentence, without being a dick about it. Good luck with learning how to be social on the internet, I hope I've helped.
Have a good labor day weekend every one!
Old Sep 2, 2017 | 11:08 PM
Tavs's Avatar
2004 e55
No prob bro. I am just trying to keep everything clear.
Old Sep 3, 2017 | 01:53 AM
clk500
Well I just order a few things from them and the heat ex is one of them
I will see when I get it
Old Sep 3, 2017 | 02:26 PM
kenneyd's Avatar
poop
High boost is great for quick blasts, but for a 30min track session, i would run a stock pulley or maybe an 83mm. cooling is a must, even with stock pulley.
After a few minutes of WOT, the heat from all that boost will slow the car down with retarded timing etc, or break something if to high.
I track frequently, although not the e55 yet. I went with a 83mm btw
Old Sep 3, 2017 | 10:29 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
Good luck, let us know what you think of everything
Old Aug 17, 2020 | 01:19 PM
Efrain Carrillo's Avatar
2 CLS55 AMG and C32 AMG
Has anyone hit 10s here in the states on a cls55 without nitrous? I want to make mine a 10 second car but wanted to ask for some more tips
Old Aug 17, 2020 | 07:11 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Yes they have. Search for 10 second club thread. A lot of different combos.
Old Oct 30, 2020 | 03:25 AM
MartinWake's Avatar
CL55
how is it?
