128k Miles on 2005 E55 - Worried about things failing soon. Any Ideas?
I am on the edge of my seat now wondering when the next thing might break, and was hoping some of the experts on this forum might chime in and give me a heads up on things I should maintain preemptively that I may expect to fail soon.Thank you for all of your responses. I am sure it will save me some expensive surprises...
Hpoefully that keeps you from a no-go on the side of the road.
It's on my soon to be done list.
Serpentine belts, all pulleys and tensioners on the engine. Buy a new supercharger idler pulley for $540 or rebuild it for $27; the DIYs are out there.
If you've never done ball joints, bushings, and tie-rod ends, now is the time to look into it.
If you're not replacing the fuel filter, pumps,and relay regularly, you're asking to be stuck on the side of the road (or blocking a bridge over a river). No more than 60,000 miles between changes and I recommend you pre-emptively replace the fuel pump relay with a larger capacity relay and socket (Unless you have a 2006 which has dual relays, not a single relay.)
Buy a Solar BA-5 battery tester and check your batteries; if at half-strength or less, replace now before they fail.
Consider pre-emptively replacing the alternator's voltage regulator; the brushes are a wear item. You may still have an alternator failure due to a bad bearing later but this is cheap and easy to perform. Be sure to disconnect the battery first! Do NOT have your key fob in the ignition when disconnecting or connecting the battery cables or jumper cables!!!
Be advised after reconnecting the battery every module in your car will have a stored code for power and communications failure. Everything will work but the first time you run a quick diagnostic you're going to see a massive amount of stored codes. So long as they are stored and not current, you can just erase them.
Ignition coils, spark plugs, spark plug cables
Shifter connector bushing (you'll hear metal clanking when shifting)
All pulleys and tensioners
Oil filter housing gaskets (there are 3)
Alarm module (drains main battery once it's internal one dies)
Heater valve
Crankshaft position sensor
Airmatic struts
Airmatic pump
SBC Pressure Accumulator
Secondary Air Pump
Heater valve
Airmatic struts
Airmatic pump
Secondary Air Pump
I think not much prevention you can do... just do fluid change, CPS, coil, spark plugs/cable. The rest just wait until happen. IMO.
When you disconnect the old fuel pumps, tie a 6'-8' length of paracord around the ends of the lines; when you pull the fuel filter out the paracord will come with it. You want enough line so the other end of the paracord is still hanging out of the hole where the fuel pumps install on the other side of the tank. Now untie the paracord from the old filter's lines, tie the paracord to the new filter's lines, and you can now pull the new lines over the saddle in the tank and to the new fuel pumps. Much easier than having your arm in the tank trying to push flexible lines over the saddle.
Remember, the newest fuel filter requires the newest fuel pumps due to new fuel line connectors. Both filter and pumps will require adapter cables to connect to the original harness.
FWIW...My fuel gauge read roughly 3/4 full and the fuel was right up to the lip of the hole
I do my own work, so everything was pretty cheap, most of these parts are in the $50-70 range, some I bought used like my alarm module from a CLS.
for me the fun is just beginning with the drifting and everything.
