I'm So Happy...Porterfield Has Finally Come Through!!!!!!
Pagid is yet to come through with a race application despite saying they will soon, but that was 5 months ago. Stock pads run around $300 if anyone's curious.
R-4 Full Race Compound
Designed specifically for heavy-duty motorsports. The carbon based semi-metallic R-4 materials allow the pad to absorb tremendous amounts of heat and dissipate it at very even rate. Carbon Kevlar material warms up to race temperature quickly, which is quite helpful during restarts, and when track time is limited. When used with cast iron and steel alloy rotors, the R-4 compound requires minimal bed-in period. Throughout the entire heat range, the carbon kevlar material will give extremely consistent modulation and predictably. This is truly the most rotor friendly racing brake pad material ever. Good for road courses, oval track, rally, vintage racing, autocross, club events or professional racing events.
R4-S High Performance Street and Autocross
For high performance and heavy-duty street conditions. Perfect for prolonged everyday street use while also being capable of tolerating the most severe street use without any fade. Rotor friendly of course. The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. R4-S compound has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brake material. Good for autocrossing, some drivers schools, solo events, and rally’s. The R4-S compound is available for virtually any vehicle sold in the US. We also offer the R4-S in pad sizes for competition type calipers that are used under street driven conditions.
www.porterfield-brakes.com
Brake ducts-done
steel brake lines-to be installed
Castrol SRF-to be installed
Porterfields-to be installed
cryogenic 2 piece rotors-future
calipers-stock are adequate
