New to me high mileage E55 - can you help me with these?
Based on the salesman feedback, I know the car has an exhaust manifold leak – so instead of replacing both manifolds, I ordered a set of Eurocharged headers. The other thing I’ll need to check: the rear left suspension drops after a day or two sitting – this will need to be diagnosed…
If you guys could let me know what you think on these 3 points, I would appreciate it very much.
1) Knowing this is a 266K km car - other than the obvious plugs, oil and filters - what would you replace off the bat? Specifically talking about powertrain and suspension parts/maintenance. Anything to look for specifically?
2) It’s been said that replacing the intercooler pump should almost be mandatory on all cars over 100k miles. Can you guys suggest a good replacement pump that would be affordable? (part # etc...) Being in Canada, I can find some on Amazon.ca or Ebay. Need to factor in shipping/duties… Or I can probably source some of them trough Napa. AND, would there be any real HP gains if I invested in a heat exchanger as well? I don't plan on doing repeated 1/4 runs.
3) I’m looking at supercharger pulleys and ECU tunes, what would be your top pick? I’m not looking for the absolute best HP gains and I’m not interested in an ice tank either. Not looking for a ¼ mile beast, just a nice power gain while retaining full drivability and reliability.
Thanks so much
I do recommend, however, you start with these two:
https://mbworld.org/forums/w211-amg/...ml#post7169029
and
https://mbworld.org/forums/w211-amg/...intenance.html
83mm pulley and eurocharged tune is a good combo. Eurocharged or shardul can organise this for you. Sounds like you need some airmatic struts, Arnott are the general pick, could also be an air line or leaking reservoir.
I ordered a bunch of parts last night. I'll try to find a used pulley kit as new pulley seems quite expensive considering shipping and import taxes in Canada. Anyone has a suggestion, let me know. As for the tunes, it might be harder to source locally here as well, so I might need to bite the bullet and order from the US.
I started working on the car today and found a couple more issues that will need my attention: There's oil all around the trasmission oil pan. I ordered a gasket for it... and I'll replace the oil while i'm at it of course. I was wondering if I should replace the trans. oil filter as well?
There's also an oil leak around the valve cover, I assume it's the gasket as well that's on his way out.I ordered 2.
If anything I say doesn't sound right, please correct me and don't hesitate to add anything I might've missed.
And about the bolt/washer, are you talking about the transmission pan bolts or a single bolt that needs replacement each time you open up the trany?
And why would you replace the dip stick? Is it a one time use. Sorry if this sounds dumb but I just can't make any sense of it!
EDIT: I just found a nice DYI for the trans. oil replacement. I understood a couple things. So we need to buy a "measuring" dip stick... How stupid is that...! Anyway... Would still love some clarifications on the items mentioned above.
The flush is to remove the old fluid from the torque converter and the cooler. One or two DIY out there if you search. Myself, I may just take it to the dealer so I don't have to mess with it....the bolt and washer are the drain plug and washer in the transmission pan.
When in doubt, ask. There are no dumb questions concerning these E55's; they are high-maintenance thoroughbreds.
As for the electrohydraulic bush you were reffering to, can you confirm we're talking about the pilot bushing pictured above so i'm 100% sure?
The transmission pan drain bolt should be replaced with a new copper crush washer each time (ideally). You may also want to replace the red clip in the top of the filler tube. They are usually about $1 and need to be snapped off before the cap can come off and replaced afterwards with a new one.
Yes measuring dipstick. I usually use pelicanparts.com or fcpeuro.com for 95% of the stuff I buy. I would strongly recommend getting genuine mercedes items. The exceptions would be if you know the OEM manufacturer ie lemforder make the suspension components for MB, or if it is something trivial like the red clip.
https://www.pelicanparts.com/More_In...VSVSI=3890.htm
https://www.pelicanparts.com/More_In...22&SVSVSI=3890
https://www.pelicanparts.com/More_In...36&SVSVSI=3890
https://www.pelicanparts.com/More_In...BZ&SVSVSI=3890
I went ahead and ordered all 4 drain plugs for the engine and trany, + crush washers.
There's got to be a better way!? Is there anyone who came up with a single operation complete oil change technique by now?
One point I wanted to add - what if I drop the pan to clean it up, reinstall a new pan seal, refill with fresh oil then drive the car 2-3 miles, come back and drop the oil using the drain plug, refill with fresh oil than repeat this drive/drop/refill process a second time? Wouldn't that produce the same result has the "flushing" procedure using the coolant lines? Unless I missed something, I see no use in disconnecting the lines up front when you can just remove the plug and easily drain the oil in the pan after it had a chance to cycle trough the whole system. What I mean is, what's the reason for playing with the oil lines if you're gonna do the oil change in a 3 step process anyway?
You can use a mityvac for transmission fluid using the tube by the firewall so you don't need to take the pan bolt out each time if you go via this route.
