2003 E55
Old Apr 2, 2018 | 03:23 PM
sok454's Avatar
2007 Audi A4 2012 E550
2003 E55
Took my Audi in to our local indy shop that also sells used imports etc. Was talking w the owners (friends of ours) and he's like oh guess did he call you about the E55 we just bought... no... '03 E55 2 owner last guy had for 12 years big stack of maint. records, 92k miles on it. Fuel unit repaired. Still has to go through the shop for a check up and will get new tires. Gonna be asking 12,900 for it. Asked about airmatic, he said hadn't been done. What else should I be cautious about?
I took it for a spin and damn does it get up... of course compared to a Audi A4 2.0 what doesn't.
Thanks everyone!
Old Apr 2, 2018 | 04:17 PM
maximus16v's Avatar
09 E63 AMG
I believe the 04 and older had the potentially bad radiators that could leak into the transmission causing glycol contamination. I would check that the rad has been replaced.
Old Apr 2, 2018 | 05:23 PM
sok454's Avatar
Thank you man! One reason I love this site.
Old Apr 2, 2018 | 08:19 PM
tw2's Avatar
tw2
SBC. Other than that just a general pre purchase inspection.
Old Apr 3, 2018 | 01:31 AM
precisionmike's Avatar
2003 C32
2003 and some very early 2004 had the radiator issue.
Old Apr 3, 2018 | 09:27 AM
E55desire's Avatar
E55
when saying "...very early 2004", approximately when did the issue get fixed? I'm in the market for an E55 and I would like to educate myself a little more. thanks.
Old Apr 3, 2018 | 10:40 AM
drothgeb's Avatar
Veteran: Navy
2005 E55
Gotta check the radiators. Lots of info about it around the forums though, do a little searching:
Originally Posted by mcleantmw
The Valeo Part # A2115000202 was the faulty radiator and Part #A2115003102 is the redesigned replacement radiator.
Old Apr 3, 2018 | 02:53 PM
sok454's Avatar
There was a post about all the things to look at that I found beneficial. I'll try to post the link to it when I get a chance.
Old Apr 3, 2018 | 03:09 PM
sok454's Avatar
Here you go. Lot of great stuff in there!
https://mbworld.org/forums/w211-amg/...ml#post7169029
Old Apr 3, 2018 | 04:30 PM
E55desire's Avatar
E55
Thanks for the info. I'm learning more and more about these cars each and every day.
Old Apr 3, 2018 | 07:54 PM
jumph4x's Avatar
W210 DRFT BNZ
Can I harass y'all to ask where the stamps/labels for this are located?
Old Apr 17, 2018 | 03:18 PM
jumph4x's Avatar
W210 DRFT BNZ
Bump, pleaaaaaase.
Old Apr 17, 2018 | 04:29 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
The radiators were also on the W203.
Valeo radiator (bad) had the upper top of the radiator crimped on using tabs bent over the plastic.
Behr radiator (good) has the upper top of the radiator crimped on using an indented crimp that has a "wavy" appearance.
See this post. Good is top photo. Bad is bottom photo. You want to key in on how the plastic top is crimped onto the metal portion of the radiator.
http://www.benzworld.org/forums/w203...ml#post4288654
Old Apr 17, 2018 | 07:15 PM
jumph4x's Avatar
W210 DRFT BNZ
Thank you thank you thank you.
