Question Purchasing an E55 AMG
Old May 2, 2018 | 06:16 PM
failboat's Avatar
none yet
Hi there,
I'm in the talks with someone for a one owner 2003 E55 AMG and I need some help from the knowledgeable forum members here. I had a pre purchase inspection done today and the mechanics told me that overall the car is in great condition and that it has relatively low km's for it's year. They mentioned that the previous owner took great care of it. I also had access to all the service records since day 1 as the car has been maintained at this shop since day 1.....
Some things that came up during the inspection were:
-Rodents had chewed through the oil cooler hose and it needs to be replaced
-Both axle seals are leaking and the car has lost a lot of oil.
-Valve cover gaskets are leaking and need to be replaced
-Differential Fluid and Engine oil need to be top'd up/changed
-Drive belts & Supercharger belts as well as pulleys are worn and need to be changed
-The car also has a stored code for the thermostat.
The struts are in good shape, front and rear brakes are also in great shape. the SBC unit was placed by original owner in 2016 and the radiator is not cross contaminating as far as the mechanic can tell because the transmission fluid appeared clean.
Given all these things the mechanics mentioned that the car was still taken very good care of and being a one owner garage kept car I'm confident that is the case...I'm wondering if you folks think that I should take advantage of this or should I pass?
We've agreed on 15,000 CAD (11,649 USD) for this 120,000KM(74,000 mile) car...I think its a fair price even given the problems....what do you think?
Appreciate any input you guys give. Thanks
Old May 3, 2018 | 10:36 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
The price sounds reasonable to me. I am approaching completion of year 4 of ownership of mine; bought it with 77,000 miles and am around 144,000 miles now.
Here is the radiator info; replace if you have the suspect radiator. Look at the crimp on the top of the radiator. Tangs bad, wavy crimp good.
http://www.benzworld.org/forums/w203...ml#post4288654
General maintenance info here:
https://mbworld.org/forums/w211-amg/...ml#post7169029
Old May 3, 2018 | 10:48 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
This is a awesome price for a E55, I would pull the trigger. The car looks in relatively good shape, and all the issues you've mentioned are easy fixes.
I would negotiate the price to offset, the cost of the repairs. If you don't move on this, someone else will, and you'll regret it.
Old May 3, 2018 | 04:14 PM
Hotsauce55's Avatar
2005 E55
Be really sure the rodents only chewed the oil cooler line & make certain that differential doesn't make a peep
I had to replace mine as it was not cheap - these cars can be savage on maintenance $
Old May 3, 2018 | 06:08 PM
tw2's Avatar
tw2
Would you work on it yourself or take it to a shop? Those are mostly easy things to fix but not necessarily cheap especially if you take it to a garage to do for you. You could easily be in for a few thousand $$ for a shop to fix all that.
Old May 4, 2018 | 12:07 AM
jumph4x's Avatar
W210 DRFT BNZ
IMHO avoid 03. Has the SBC system and short rack. I'd go for a 2006-2007.
Coming from a guy who did a bunch of stuff on his 2003.
Old May 4, 2018 | 12:13 AM
tw2's Avatar
tw2
They all have SBC 03-06.
Old May 4, 2018 | 12:23 AM
jumph4x's Avatar
W210 DRFT BNZ
Oh right, then it's the 6.2L. I forget, good catch. SBC is replaced too, I see.
I guess main reason to get a later one is a quicker steering rack.
I suppose most people do not care for this.
Good price.
Old May 4, 2018 | 12:32 AM
tw2's Avatar
tw2
Yep the E63 dropped SBC. Haha I think you may have slightly different requirements in terms of the unique driving you do with a car!
Old May 4, 2018 | 08:59 AM
slownrusty's Avatar
'06 E55 K2
Decent price but agree that the '05 and '06 are the models to buy.
Old May 4, 2018 | 10:09 AM
Yuille36's Avatar
I think that the 06 models are the most preferred, as it is the last year of the W211 E55.
Old May 4, 2018 | 04:57 PM
tw2's Avatar
tw2
A great condition 05/06 is ideal but 03 in good condition is infinitely better than other years of higher mileage and questionable maintenance. As long as you don't specifically want options only available on the newer years (which I can't name one) then there are only a handful of design differences- radiator as already mentioned which are quite cheap. There is also a difference with the fuel pump fuse/relay design to be aware of. There will be other minor things but this is all I can think of off the top of my head.
Old May 4, 2018 | 06:26 PM
failboat's Avatar
none yet
Thank you to everyone who replied with helpful advice. I ended closing the deal as the car was just too beautiful to pass up in person.
I am really happy to be a member of the AMG club! So stoked to explore the potential of this engineering masterpiece.
Thanks again for all the insight folks
Old May 4, 2018 | 06:31 PM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
Congrats - you got a car that cost $80,000 when new for less than $12k.
I call that a Bargain.
Old May 5, 2018 | 09:09 AM
forcefed4door's Avatar
05 E55, 06 Audi S4
80k new is on the low side for sure. Congrats for the mileage that's an excellent deal.
